Old 02-15-2024, 04:15 AM
Daveski69 Daveski69 is offline
Default Is this a GUI bug or a feature?
How do I get to this mode where, in the mixer window, the send fader covers up the space of all 5 collapsed sends instead of pushing them down,. Occasionally I will look at my screen and see it showing this way but cannot figure how I got there, like in my normal ham-handed typing I hit a key combination. It really saves screen real estate and I wonder if I am missing something new and basic....I’m using Protools Ultimate, latest version on a Mac Pro M2 rack
Here’s a screenshot:
http://www.davidkowalski.com/images/part1.png
and showing the “normal” way:
http://www.davidkowalski.com/images/normal.png
Last edited by Daveski69; 02-15-2024 at 04:35 AM. Reason: new links to screenshots
Old 02-15-2024, 05:41 AM
zoff zoff is offline
Default Re: Is this a GUI bug or a feature?
View> Expand Sends, then choose which send or sends to expand.
macOS Sonoma 14.2 Intel Core i9 MacBook Pro(16,1) 2019, 32 GB RAM Pro Tools Studio 2023.12, RME Babyface Pro
Old 02-15-2024, 06:03 AM
I probably was not clear in my initial post.
What I meant is, If you look at the 2 screenshots, you will see that the send A fader takes up the space of where the 5 unexpanded sends would be, with no increase to the vertical screen space used.
In the second one, the unexpanded sends for B,C,D and E are pushed down underneath, increasing the vertical mixer window.
I keep a lot of elements in view on my mixer window and any space saving feature is definitely desirable.
Old 02-15-2024, 08:29 AM
sw rec sw rec is offline
Uncheck “expanded sends.”
Old 02-15-2024, 08:41 AM
Tweakhead Tweakhead is offline
you've taken the two screenshots using different mixer display widths, ie Narrow & Normal. Is this affecting the result ?
Old 02-15-2024, 11:19 AM
skylar_battles skylar_battles is offline
You might be accidentally Command clicking the the arrow on a send which expands it into view. Or Option Command clicking which brings all sends into view.
Pro Tools Ultimate 2024.3.1
MacBook Pro 16"
Apple M2 Pro with 12‑core CPU, 19‑core GPU, 16‑core Neural Engine
32 GB unified memory
1TB SSD storage
Ventura 13.6.4
Old 02-16-2024, 08:45 AM
No, narrow or wide view has no bearing
Old 02-16-2024, 07:43 PM
I have never seen this behavior, I suspect it's a bug.
I can't find any way to reproduce what you are seeing (Intel Mac running 2023.12.0 Studio). Expand a single send, expand all sends, mute/unmute sends, wide/narrow view, mon, stereo, etc. tracks, routing folders, etc all work as expected for me via keyboard shortcuts or the View menu options.
Have you started with trying to trash prefs?
Does this happen in multiple sessions or only one?
Does it only happen for folders/routing folders
Old 02-16-2024, 11:26 PM
BScout BScout is offline
This is a view that used to exist in PT 10. There was single send vs assignment view. Seeing as you aren't on PT 10 (and this was taken away in PT 11), this is a bug -- probably some old code.
Old 02-20-2024, 09:20 AM
marianna's Avatar
marianna marianna is offline
Dave
I created a case and asked tech to take a look to determine if it is old code that needs to be fixed.
Case # 04760354
Thanks and they will get in touch with you.
Marianna
Marianna Montague
Sr. Dir. CX and Community | Customer Advocate
[email protected]
cell +1 (813) 493-6800
AOL IM avidmarianna
Twitter Avidmarianna
We're Avid. Learn more at www.avid.com
PT8 feature or bug? poly915 Pro Tools TDM Systems (Mac) 1 10-29-2010 02:01 PM
Feature Doc M&E Andy Hay Post - Surround - Video 9 05-19-2007 07:08 PM
New feature? CraigLearmont Pro Tools TDM Systems (Mac) 9 03-06-2006 08:12 PM
Is this a bug or a feature?! mannikin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-27-2005 04:36 PM
new feature please CLee ProControl, Control|24, Command|8 2 08-05-2002 07:08 AM
