Old 05-07-2022, 09:23 AM
its2loud its2loud is offline
Default Re: 10+ sec delay loading plugins with 2022.4 update
Did you do a proper uninstall and then install of the new HD driver?
Try running the software without the HDX or HD Native card. Does the system run smooth then?
I would start with a complete uninstall of everything, including the HD driver and then reinstall.
In the future, I would avoid installing new versions of Pro Tools over old versions on Windows. This is asking for trouble. Always do an uninstall first.
https://avid.secure.force.com/pkb/ar...lation-Process
Old 05-07-2022, 06:41 PM
EGS's Avatar
EGS EGS is offline
Originally Posted by stevedresser83 View Post
... I open up decapitator and it stalls out about 15 seconds. Fab-q, loads instantly. Go to audiosuite to apply a reverse to something, 10 sec...
Have you tried uninstalling (or at least moving to unused folder) ALL 3rd party plugs? I'd uninstall Pro Tools AND all 3rd party plugs. Reinstall PT + stock AVID plugs & test. Go to the first plug vendor's site, download & install latest version & test. Repeat for each vendor.
Click for audio/video demo
Click for resume
Old 05-07-2022, 06:43 PM
EGS's Avatar
EGS EGS is offline
Originally Posted by its2loud View Post
...I would start with a complete uninstall of everything, including the HD driver and then reinstall...
Yes. Ditto for 3rd party plugs.
Click for resume
Old 05-07-2022, 06:52 PM
EGS's Avatar
EGS EGS is offline
...Windows 10 Professional 10.0.19041
Take all Windows updates.
Windows 10 Pro
Version 21H2
OS Build 19044.1682
and run Virus & threat protection
Click for resume
Old 05-08-2022, 01:16 AM
stevedresser83 stevedresser83 is offline
thanks for the tips. Will try all this and report back
  #16
Old 05-09-2022, 04:50 PM
I uninstalled everything avid related, deleted all avid folders everywhere. Fresh install, slowly re-installed plugins checking along the way. So far so good. Thanks
  #17
Old 05-10-2022, 05:53 AM
EGS's Avatar
EGS EGS is offline
Cool. Also:
Windows 10 Pro
Version 21H2
OS Build 19044.1682
Click for resume
  #18
Old 05-11-2022, 12:59 AM
well the problem is back. Was fine for a number of sessions. Can't totally make sense of what is causing it, too many moving factors. I went back to a mix session that was problematic last week before I uninstalled and it took 25 minutes for it to open (no joke). The same session was opening fine after I reinstalled everything a few days ago at that point I and had almost every plugin installed that I do now. I just installed the air bundle and a couple others today, could be one of those. What's weird is I uninstalled the plugins I installed today but its still taking forever to load. It's like something got corrupted. May need to fresh install again. Not sure. I do know the previous version of protools I had all these same plugins installed plus even more and it never had this issue, so something new is tweaking it out.
  #19
Old 05-11-2022, 08:34 AM
EGS's Avatar
EGS EGS is offline
... Can't totally make sense of what is causing it, too many moving factors ...
Since you are in troubleshooting mode, I suggest you methodically do one troubleshooting step at a time until the problem is isolated.
1) Uninstall ALL things PT & all 3rd party plugs. Run CCleaner & CCleaner reg cleaner. Take ALL Windows updates & run a full spyware scan. At this point, take a boot drive image (Macrium Reflect free version is fine). Make sure you know how to restore the image, if need be.
2) Install PT and stock plugs only. All AVID optimizations and also all AVID troubleshooting steps - do not skip a single one. Test test test. Take yet another boot image.
3) Do an import session data from the suspect session into a brand new empty session. This will determine if the session itself is corrupt.
4) Install one of your 3rd party plugin venders. Make sure to install by going to the manufacturer website and get the current version. Test test test. Import session data from the suspect session into a brand new empty session. Take another boot image.
5) Repeat for each 3rd party plug.
Click for resume
  #20
Old 05-16-2022, 01:23 AM
UPDATE : I ultimately gave up on the new version of protools. I reverted back to 2021.6 and copy pasted my old plugin folder back in and it works perfect.
2022 update: routing Mac Built-In audio to PT? Eric Lambert Pro Tools 27 05-13-2022 12:41 PM
Does the new 2022.4 update fix the loosing I/O setting bug K Roche Pro Tools | Carbon 7 05-01-2022 02:56 AM
Pro Tools 2022.4 update is a DISASTER! jplumlee Pro Tools 9 04-28-2022 12:58 PM
Pro Tools plug-ins bundle 2022.2 update? MacMax Pro Tools 2 03-30-2022 07:27 AM
Jan 2022 Apple Security Update bricking display again OAG Avid S1, S3, Dock and Control App 2 01-04-2022 09:46 AM
