Old 01-04-2022, 06:13 AM
OAG OAG is offline
Default Jan 2022 Apple Security Update bricking display again
New Mojave Security Update Jan 2022 has done it again.
All S1 Displays Full Yellow.
Mac Pro 5 1 2012, Mojave, PT Ultimate 2020.11, Dock, S1, Eucon 2021.6, Motu Ultralite Mk3
Old 01-04-2022, 08:56 AM
Default Re: Jan 2022 Apple Security Update bricking display again
Are you sure? I thought they fixed this in the current version. Your EC 21.6 won't have that fix.
Old 01-04-2022, 09:46 AM
OAG OAG is offline
You're quite correct Frank. Thank you.
I believe I had a patched 2021.6 which fixed the last yellow brick road, but obviously not this one.
I missed 2021.10, I think because it was all working fine and I didn't need the new stuff. Eucon was working really well (after a very bad start - ended up with a dedicated WiFi/ethernet router straight off the Mac Pro as everything was always falling off).
So I've gone up to 2021.10 now including all firmware and control updates and I have the displays back on the S1 tablet.
I can't, however, get my Dock tablet to add to Eucon.
Which is a bit of a concern. And a lot worse than some yellow blocks.
But I'll see what I can do with some coaxing..
*******Fix for Apple Security Update bricking displays******* EddieJones Artist Series 65 12-31-2021 10:22 AM
*******Fix for Apple Security Update bricking displays******* EddieJones Avid S1, S3, Dock and Control App 61 09-06-2021 11:52 PM
Apple Security Update 2021-004 Eucontrol Hotfix Felix Rost Pro Tools 0 08-05-2021 05:29 AM
Do not load latest Security Update from Apple Park Seward macOS 5 03-12-2015 06:22 AM
apple security update 2009-002? nst7 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-14-2009 11:45 AM
