Old 06-24-2016, 04:33 PM
johanispro3 johanispro3 is offline
Default Pro tools inserts malfunctioning?
I've recently upgraded my studio with a patchboard, I wired everything up and it all works. Except for one thing; the inserts in pro tools. I have connected the inputs and outputs of my universal audio apollo and I connected an echo (for testing purposes) between them. It seemed to work, I select insert 5, connect my echo between input and output 5 and it echos my track. But after some more experimenting I discovered that only 5 seemed to work properly. The outputs correspond to the inserts, I select insert 3, it gives a signal on output 3. But, only input 5 seems to work, regardless of what insert I'm using, input 5 connected to the output with the corresponding insert works. This means I can only connect one hardware device because only input 5 can be used? I have checked the I/O settings multiple times, I have checked the wiring countless times and I just can't figure out what's wrong. If anyone had help or advive it would be greatly appreciated.
Old 06-24-2016, 04:36 PM
Extreme Mixing Extreme Mixing is offline
Default Re: Pro tools inserts malfunctioning?
I think that's the Apollo. I have a client with one and the way it's set up is not the first way you might think... Do a little looking in that manual.
Steve
Steve Shepherd
Extreme Mixing
master track keeps malfunctioning clingerpratt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-29-2009 10:12 PM
We can help you a with malfunctioning ProControl Bookerv12 ProControl, Control|24, Command|8 0 11-08-2008 05:27 AM
Headphone Jack Malfunctioning Hellgi ProControl, Control|24, Command|8 0 07-07-2008 04:07 PM
002 "clicking" and malfunctioning Ormond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-17-2005 12:17 PM
Malfunctioning ProTools! (please help!) toddamo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-22-2002 01:31 PM
