Old 12-12-2010, 02:54 PM
jcmckay jcmckay is offline
Default PT9 H/W Buffer Problems. Any Ideas?
Greetings,
I am a new to the forum and have been trying to find this answer everywhere with no luck. I was hoping someone here might be able to share some knowledge.
I just recently upgraded from PT LE 7.4 to PT 9 on my iMac. I have an Mbox 2 Pro and have done all driver updates as well. Since updating, I am unable to play back any session because I consistently receive the "H/W Buffer Underflow" error. I have tried multiple settings in the playback engine with no luck.
I have clean uninstalled and am running Snow Leopard. If anyone can help it would be greatly appreciated.
Thanks,
John
Old 12-12-2010, 03:00 PM
firebass305 firebass305 is offline
Default Re: PT9 H/W Buffer Problems. Any Ideas?
Hey John -
I've had similar issues. The tip I got was to go to Setup>Hardware> and under clock source switch it to SPDIF, wait till it gives you the error message, switch it back to internal, and your sessions should play without a hitch.
This won't fix it forever; you may have to do it every once in a while and it's pretty annoying, but at least it will get your sessions playing again. 60% of the time, it works every time. . .
Actually it works every time...
Old 12-12-2010, 03:15 PM
Thank you for the quick response. I actually just hooked up my Firestudio Project and it seems to be working without a flaw.
I will definitely try the SPDIF trick the next time I hook up my mbox 2 pro.
Anyone else have any ideas? Has anyone else experienced issues with the new mbox 2 pro drivers?
Thank you all very much for your help, it is very much appreciated.
John
Old 12-12-2010, 03:22 PM
I had this problem on PT 8 too - it's not a new thing. For me, it usually happened when I was opening up a session that had been created on a different computer (not the one I was running the Mbox 2 Pro on)
Supposedly it is an issue unique to the Mbox 2 Pro.
Old 12-12-2010, 06:46 PM
I guess that makes sense. I upgraded from 10.5 to 10.6 and PT 7.4 to PT 9. The previous sessions were created in 7.4.
Does this mean my mbox 2 pro is absolutely useless now? That would be unfortunate. Any ideas?
Old 12-13-2010, 02:09 AM
The Dougfather The Dougfather is offline
Default
A lot of underflow errors used to be caused when combining FireWire 800 & 400 on the same bus.
Is this applicable to your setup?
Sent from my iPod touch using Tapatalk
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Old 12-13-2010, 02:13 AM
suicune suicune is offline
Once had those errors from an mbox 2 pro when the firewire cable developed a fault. If you haven't tried changing the cable already I definitely would give that a go.
M2 Studios
Wolverhampton, UK
http://www.madhat.co.uk
Pro Tools 9 and Reason 6 get out of sync with buffer change, ideas? PabloB macOS 0 10-23-2013 09:15 PM
Having problems? Try these ideas musicman691 Tips & Tricks 1 03-23-2013 08:07 AM
Firewire problems. Any ideas? johnnyv Pro Tools TDM Systems (Mac) 27 03-17-2010 11:35 PM
plug ins causing problems? Any ideas? edfreeze Virtual Instruments 0 02-05-2010 09:49 AM
M-Powered 6.8 Plugin problems - any ideas? Halon Pro Tools M-Powered (Win) 4 12-17-2005 09:47 PM
