Old 11-09-2010, 08:46 AM
rogee rogee is offline
Default Reason, Protools, midi controller timing
I cannot sync my 3 devices
anybody have tips?
timing is way off
Dell Inspiron E1705 Genuine Intel(R) CPU T2500 @2GHz 2GB DDR2 RAM
Windows XP service pack 3, PTLE 7.3.1
OWC Mercury Elite Al Pro external HD
MBox2
Old 11-09-2010, 08:56 AM
spkguitar's Avatar
Default Re: Reason, Protools, midi controller timing
Originally Posted by rogee View Post
anybody have tips?
We might, but we would need more information.
Which MIDI controller?
What, exactly, is it that you are trying to do? (a step by step of your process, your expected result, and then your actual result would help)
What, exactly, is the problem? "timing is way off" is kind of vague.
Old 11-09-2010, 12:51 PM
well it's the roland xp-80 keyboard that I'm using 95% of the time as just a controller.
after running it through reason to rewire to protools, the playback is really jerky/sporadic.
sometimes it sounds good while being recorded but once played back it's terrible. I've been messing with the playback engine in protools using up to 90% cpu usage.
I don't know if there's much I can do about it in Reason.
I've been through the optimization steps for windows xp many times and I will have to upgrade computers one day but I don't always have this issue.
MBox2
Old 11-09-2010, 01:04 PM
spkguitar's Avatar
And you have the XP-80's "Local Switch" set to "Off" in the MIDI settings on the XP-80?
Do you have the same problem when using Reason in Standalone mode? Or is it just when rewired into Pro Tools?
Are you using any other plugins in Pro Tools? If so, which ones?
Which version of Reason?
Old 11-10-2010, 12:42 PM
local switch off
just when rewired
I have the waves maserati plugins going as well.
reason 3
thanks
MBox2
Old 11-10-2010, 01:56 PM
spkguitar's Avatar
reason 3
Woah! OK.
You know you're two versions behind at this point, right? Are you at least updated to version 3.0.4 and have you applied the Rewire Update? If I remember correctly, that was important for that version of Reason.
Old 11-10-2010, 02:21 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Talk about Legacy
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 11-13-2010, 05:38 PM
yeah it's 3.0.4
thanks for the rewire update too
I'm not sure if I did that
MBox2
Old 11-15-2010, 06:29 AM
it seems to be working now
I haven't really fixed anything, though
MBox2
Sync issue, pro tools MIDI and MIDI controller, timing issue Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-29-2011 07:57 AM
Midi controller and Protools with Reason REWIRED! DTrigga 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-01-2005 09:03 PM
Cant play my usb controller in protools (reason) primo99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 10-19-2004 10:12 PM
Reason, RME, PTle and midi timing problems bennals 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 01-22-2002 03:58 AM
ProTools MIDI timing Dan L MIDI 24 05-03-2001 02:58 PM
