Old 05-20-2016, 01:07 PM
peter5992 peter5992 is offline
Default Waves DTS Neural Surround Plugin
Hey guys:
Have you seen this seen this:
http://www.waves.com/bundles/dts-neu...und-collection
Anyone tried it yet? How does it stack up to other surround encoders, e.g. the Neyrinck (other than that it 50% less expensive)? Or are they just different industry standards (see below), and depending on the delivery format, you may need either one or the other?
Sorry if this sounds ignorant, I'm fairly new to surround (other than as a consumer that is).
https://www.audioholics.com/audio-te...of-the-formats
Old 05-20-2016, 09:35 PM
smurfyou smurfyou is offline
Default Re: Waves DTS Neural Surround Plugin
This one isn't an encoder, it's an upmixer for creating multichannel content from mono or stereo sources.
~Will
Old 05-21-2016, 11:33 AM
Cheesehead Cheesehead is offline
It is an encoder, one of the plugins will encode multichannel to LtRt.
I tried it up against the Neyrinck, 5.1 to LtRt and my feeling was that some of the punch and brightness was lost after the stereo encoding on the DTS.
Maybe because of the different limiters?
Anyhow I'm sticking with the Neyrinck, your mileage may vary.
I thought the upmixers did a good job, but are very center heavy.
Probably great for upmixing full program, but not so great for music & FX that have to sit behind dialogue.
I wish they would make a DTS Headphone plugin and the DTS loudness tools as plugs.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 05-21-2016, 12:39 PM
tom_lowe tom_lowe is offline
It'd be more accurate to call it a downmixer rather than encoder as it won't encode to DTS formats.
Old 05-21-2016, 05:48 PM
Leverson Leverson is offline
Where does it say it encodes into LtRt? Everything I've read looks like a downmix to stereo.
Old 05-21-2016, 09:46 PM
Well I meant it does not encode to any DTS formats.
But I don't see any mention of matrix encoding. Just downmixing.
~Will
Old 05-22-2016, 12:16 AM
Mike Thornton's Avatar
Mike Thornton Mike Thornton is offline
Check out our review by Alan Sallabank http://www.pro-tools-expert.com/home...und-collection
Mike.
Mike Thornton MIPS
Chairman Of Production Expert Ltd - home of Pro Tools Expert
Old 05-22-2016, 09:59 AM
Postman Postman is offline
Cheesehead is right. Take a look at pg 10 of the user manual for this 7.1/5.1 to stereo downmixer. One of the choices for output is called "Lt-Rt". Probably not the same as Dolby's term "LtRt" but I might guess very similar in overall concept. The manual implies phase/time manipulation, probably differently done than Dolby's, The description certainly sounds like a matrixing scheme to me but that is only my guess. I haven't auditioned it and have no plans to.
Cheesehead, is the "Lt-Rt" output listenable as stereo? The manual would seem to suggest it is, and it makes sense in the context of the suite of plugins.
PTE shows how well they could encode individual surround channels of sinetone into "Lt-Rt" and then restore them into the proper surround channels. I'd be more interested in how this Lt-Rt encode/decode process deals with complex surround sound. Dolby Pro Logic II has no trouble encoding/decoding 5.1 individual channels in the same way as PTE demonstrates here. Problems arise when a lot of channels are playing at once. With Dolby's systems you'll rarely get all the same material from all the same speakers and there are the infamous "steering" problems.
system specs in profile
Old 05-23-2016, 05:18 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
The width button is actually divergence.
IMDB
Old 05-23-2016, 06:25 PM
8dB.co.uk 8dB.co.uk is offline
The centre and lfe channels are the two most mis-used in my opinion.
To make a fold down comparable, you have to use the centre channel on music and FX. If their presence is clouding the dialogue on the centre channel, turn them ALL down.
If you only ride the centre level that way intelligibility complaints lie.
Remember that the centre channel is also an important front phase "anchor". To bed in ADR and Foley properly, you have to use centre Atmos, FX and most importantly reverbs. If you try to match stereo or 4.0 / 6.0 reverbs to mono dialogue, you will get a shifting dialogue image and "wrap round" of reverbs and FX that are meant to be bedding in.
Above all, NEVER rely on a phantom centre or dialogue divergence. Phantom centre only works in the listening sweet spot, which in a lot of home installations is very small, as it is in most big cinemas. We have a centre channel for a reason. It anchors dialogue, FX and even music to the centre. For 80% of the audience, ADR will never be believable if dialogue comes out of the centre but the Foley, FX and reverb that are supposed to be giving the illusion that it's the original sound, are coming out of the left and right, or even worse wrapping around the rear.
If you rely on dialogue divergence, then that same proportion of the audience who are outside the sweet spot, won't ever think that the dialogue is coming from the middle.
Just my tuppence worth as a mixer who's worked in surround for 26 years, and worked with DTS kit since '97 (I think).
DTS have always been great to work with. The other main player has always been very helpful too.
Sent from my D5803 using Tapatalk
Pro Tools Utimate 2018.7, on -
i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB;
Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB;
"Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB.
RME FireFace802 + ARC, RME Babyface
Avid D-Command, Artist Control, V-Control, Korg MicroKontrol
7.1.2 Presonus Monitors
HTML code is On
LE Surround plugin the_dr38 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-20-2006 05:34 AM
Anyone using Waves 360 Surround and/or Dolby Surround plug? Wheelieboy426 Pro Tools TDM Systems (Mac) 5 12-10-2002 02:13 PM
Waves 360 Surround Tools Hooker Post - Surround - Video 1 10-29-2002 07:22 AM
5.1 Surround Plugin or Addon David Fisher 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 09-22-2002 09:29 PM
5.1 surround plugin for PTLE? espron 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-26-2002 07:19 AM
