DIGI OO2 CLICKING AND VALIDATING PROBLEM..HELP
HELLO,
My DIGI 002 desktop has been working fine. 2 weeks ago it started to act up. I would be able to launch protools 6.9 fine and use it. After about 20 minutes, I would hear a clicking sound and see the validating on the mixer window. Sometimes it would catch back on and I just hit continue when the software displays an error that it lost connection but other times it just clicks and the LCD blinks. Once I turn off & on I can proceed but it will happen again. I haven't changed anything and also did reset the hardware and the firmware is current. I also used another power outlet but no dice. I did research this problem online and notice there was problems with the 002R harness and that it was causing this same problem. I wonder if that's my problem with the mixer type 002. it also does it in stand alone mode which would have nothing to do with the PC. Anyone had this problem?? How can I fix this?? Thanks for reading... |
Re: DIGI OO2 CLICKING AND VALIDATING PROBLEM..HELP
hello metrostarr,
I am just having the same problem as of today. It came out of nowhere. I made no soft or hardware changes but there it was: 002r randomly resetting itself both during PTLE operation and otherwise. Thought it could be a voltage issue and connected the unit to the uninterrupted power supply but that did't seem to help... Did you find a solution? Anybody had a similar issue? cheers. |
Sounds like the power harness.
Quad 2.5 G5, 4.5G RAM |
Hello again...
Check this thread out for the solution that worked for me: Paddy Nixon's solution + what I had to add to it... Cheers, Derin. |
happened to me, called digidesign they sent me the replacement parts free of charge no hassle works fine now
Digi002 LE 8.0 XP Pro SP3 Athlon 64 FX-53 K8V Deluxe 4GB Dual Channel WD 80GB System WD 300 production 2X300 RAID1 (for backup) NVIDIA GForce4 Dual Head UAD1 Plug-in card ----------------------------------------------- Any sufficiently advanced technology is indistinguishable from a rigged demo. ----------------------------------------------- |
DIGI 002 Clicking?????? | dylan thermos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 07-17-2015 12:01 PM |
Digi 002 Clicking?????? | dylan thermos | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-16-2009 04:23 AM |
Digi 002 starts validating during a session | 4themax | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-24-2007 12:48 AM |
Digi 002 validating Interruptions | Leon B | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-23-2006 09:30 AM |
Another Clicking Problem | soloan | Pro Tools TDM Systems (Mac) | 3 | 07-21-2005 11:14 AM |
