Old 04-22-2023, 11:18 PM
Guy McDude Guy McDude is offline
Default Dont Use PCI card mounted NVMe drives w/HDX
Hi fellow HDX users,
After quite a bit of trouble shooting Ive discovered that HDX/ and current PT software does not like sharing a PCI bus with PCI mounted NVMe drives in expansion chassis.
I was getting constant -9171 errors if I tried saving on the fly, like Ive done for decades.
After tons of trouble shooting, I contacted Sonnet Tech, and they confirmed that its a known issue that they informed Avid about.
The offered solution was moving the PCI drive card to another chassis and TB4 port, or go with one of those small, unpowered dongle enclosures and a fresh port.
going to try a few options next week.
So if you too have drives like this in an expansion chassis, and getting odd errors, this would be the first place id check.
Best,
Sean
my rig specs:
Mac studio M1 / Monterey
64 GB ram
PT 2022.12
HDX
UAD Octo
Sonnet Tech Echo III
3x HD16
Samsung 980pro 2 TB
Samsung 980pro 2 TB
Samsung 980pro 1 TB
Sonnet M.2 4x4 PCIe 3.0 Card for up to Four M.2 NVMe SSDs - Silent Edition
Best,
Sean
Sean McDonald
Red Medicine Recording LLC
Sofa King Music Services
http://www.seanmcdonald.com
Old 04-23-2023, 12:04 AM
BScout BScout is offline
Default Re: Dont Use PCI card mounted NVMe drives w/HDX
This is a problem with a chassis only. Your global concern is incorrect as the subject. You might want to narrow that scope down.
Works just fine in a Mac Pro 5,1 or a 7,1. Plenty of people have been using them for years.
Old 04-23-2023, 12:07 AM
sorry?
I mentioned sonnet tech and expansion chassis and NVMe drives.
My apologies, If that was not clear enough.
I will edit my post.
Best,
Sean
Sean McDonald
Old 04-23-2023, 02:07 AM
uptheoctave uptheoctave is offline
Could it be Sonnet M.2 4x4 related?
I have a Sonnet Echo III with an OWC 4m2 and a Highpoint SSD7505 Hardware RAID card in the same chassis as an HDX card.
I am not getting any -9171 errors.
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
Old 04-23-2023, 09:25 AM
Good question.
I tried the Startech card as well, and got the same errors.
Are you writing your sessions to the raid setup, or is that just a backup?
What size drives are you using?
Thanks for the info
Best,
Sean
Sean McDonald
Old 04-23-2023, 09:44 AM
Originally Posted by Guy McDude View Post
Good question.
Thanks for the info
The RAID card is my main audio drive, so I am writing to it all the time.
I am using 4x2TB in RAID 1+0.
The OWC card has 4x 2TB drives a JBOD, my samples, VI, orchestral libraries.
The drives are Samsung 980 Pro in the RAID card and 970 Evo in the OWC card.
James Richmond
Affiliate Links:
Old 04-29-2023, 11:38 AM
track track is offline
I've just installed a WD_BLACK 4TB SN850X NVMe with a
OWC Accelsior 1M2 M.2 SSD to PCIe 4.0 Adapter Card to my Sonnet Echo Express III along side an HDX card and cannot get a session running on it.
I immediately get an AAE 2 error.
Old 04-30-2023, 03:16 PM
TrentWilliams TrentWilliams is offline
Can confirm I went through this troubleshoot when I bought my HDX rack-mount chassis.
My solution was to put nvme drives into an external OWC 4M2 thunderbolt chassis and run them both on different thunderbolt busses, haven't had an issue since.
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • DockMac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 05-13-2023, 09:51 PM
thanks for the info.
Agreed, once I put the PCI / NVMe card in a different expansion chassis, all of the errors/ issues went away.
Very disappointing that Avid was told this by Sonnet, but that info was never shared with users.
Best,
Sean
Sean McDonald
Old 05-13-2023, 09:55 PM
thanks for sharing.
I went with another Sonnet product, their Break Away GPU box, its work well.
If you have just the one drive, this might be your best fix.
https://www.amazon.com/gp/product/B0...1?ie=UTF8&th=1
best of luck,
Best,
Sean
Sean McDonald
Are my internal NVMe drives causing PT to crash when recording multiple tracks? loud neighbor macOS 32 03-23-2022 02:14 PM
Mac Pro 5,1 Cost effective NVMe SSD drives Howardk Pro Tools HDX & HD Native Systems (Mac) 12 12-23-2020 11:18 PM
Bootable Thunderbolt case for NVMe drives (Samsung 950 etc) propower General Discussion 1 10-27-2016 04:11 PM
Rack-mounted fw hard drives... recommendations? Jahz Pro Tools TDM Systems (Mac) 13 05-16-2005 01:54 PM
IDE drives for backup, internally mounted to a G3 Alécio Costa Pro Tools TDM Systems (Mac) 11 02-28-2002 09:04 PM
