How do I clean up my IRQ\'s?
I don't know how to get rid of some of these, or if I need them...? Please let me know, thanks.
IRQ 0 System timer OK IRQ 1 Standard 101/102-Key or Microsoft Natural Keyboard OK IRQ 2 Programmable interrupt controller OK IRQ 3 Communications Port (COM2) OK IRQ 4 Communications Port (COM1) OK IRQ 5 ACPI IRQ Holder for PCI IRQ Steering OK IRQ 5 VIA Tech 3038 PCI to USB Universal Host Controller OK IRQ 5 3dfx Voodoo Series OK IRQ 5 Creative SB Live! OK IRQ 6 Standard Floppy Disk Controller OK IRQ 7 Creative SB16 Emulation OK IRQ 7 ECP Printer Port (LPT1) OK IRQ 8 System CMOS/real time clock OK IRQ 9 SCI IRQ used by ACPI bus OK IRQ 9 ACPI IRQ Holder for PCI IRQ Steering OK IRQ 9 VIA Tech 3038 PCI to USB Universal Host Controller OK IRQ 9 VIA Tech 3038 PCI to USB Universal Host Controller OK IRQ 10 ACPI IRQ Holder for PCI IRQ Steering OK IRQ 10 Texas Instruments OHCI Compliant IEEE 1394 Host Controller OK IRQ 10 VIA USB 2.0 Enhanced Host Controller OK IRQ 10 Digidesign Digi 001 OK IRQ 11 ACPI IRQ Holder for PCI IRQ Steering OK IRQ 11 VIA Tech 3038 PCI to USB Universal Host Controller OK IRQ 12 PS/2 Compatible Mouse Port OK IRQ 13 Numeric data processor OK IRQ 14 Standard Dual PCI IDE Controller OK IRQ 14 Primary IDE controller (dual fifo) OK IRQ 15 Standard Dual PCI IDE Controller OK IRQ 15 Secondary IDE controller (dual fifo) OK |
Re: How do I clean up my IRQ\'s?
I'm getting spontaneous reboots during sessions and I think it's from the IRQ's, everything else seems ok... The CPU temp is about 41C when it crashes, I don't think that's hot enough to crash it...
Antec Performance Plus1080 SOHO File Server Case Asus A7V 333 (Raid disabled) AMD Athlon T-Bird 1000 Zalman CNPS3100 Fan w/flower heatsink Western Digital 40 GB 7200 RPM HD 512 MB Mushkin RAM (1 stick) Digi 001 Soundblaster Live Platinum Soundcard Voodoo5 5500 Video Card Windows ME |
go into your BIOS and disable everything you dont use right now , such as onboard sound, network, usb, serial ports, parralel ports, infrared ports, and in your case...the most important, the firewire (it is sharing IRQ with the digi001, and the digi001 is egoistic, it doesnt like to share)
if i look at it....i see these ports eating up irq's irq 3 com2 irq 4 com1 irq 7 parallel printer port (lpt1) irq 10 firewire interface irq 10 usb2 interface irq 13 PS/2 mouse port I am NOT saying to disable the whole bunch, but only disable the port you dont use. This will free up some irq's. Then locate the "Update ESCD" or something like that in the BIOS to have all the plug and play stuff assigned new irq's. If that doesnt put the digi001 on its own irq (well...it will still share with a "ACPI IRQ-holder for PCI-steering") try moving the pci-cards around in your system I also think its possible to hard-assign a pci-slot to an irq with your mobo...
What's that? - That's the machine that goes "pling". Bastiaan |
Get rid of the old soundblaster and remove the 2dfx pci graphics card and get your self a agp video card.
don't dump the soundblaster. go into bios and disable your serial ports and printer port if you're not using them. also disable your usb ports if you're not using them. if you do use usb, disable all but 1 (including usb2). same goes for 1394 if you're not using it. then get rid of acpi - this will free up some irqs.
i love my apple iPhone! |
Does the onboard firewire port eat up resources? Can you go back and forth enable and disable?
check this out:
http://basstardz.dhs.org/TIPS/TIP009_optimize-IRQs.HTM and, yes, onboard firewire does use an irq resource...
If you get a new video card, check out the ATI Radeon 7500 or 9000. Works good with this board. Allen [img]images/icons/wink.gif[/img] |
Need help with XP irq's... | robstudio | Pro Tools TDM Systems (Win) | 2 | 08-19-2002 10:39 AM |
IRQ's what's the big deal? | oslpchris | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 38 | 07-01-2002 09:54 PM |
IRQ's | mattm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 01-07-2002 12:29 AM |
IRQ's on my Dell..?? | Badooker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 01-03-2002 10:34 AM |
irq's | vide | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-31-2001 02:53 PM |
