Is there such a thing as too much RAM?
Is there a point where adding more RAM doesn't have much of an effect. I have 524 Meg on my PC and I'm wondering if adding more will increase performance (increase capacity to use more of plug-ins). I was told by one person that adding after you're at 500-600 Meg doesn't really do much.
Any thoughts??? |
Re: Is there such a thing as too much RAM?
Thanks for the info. I appreciate it.
Adding more than you have won't add any performance. It may even hurt your performance because of Windows 98 and ME's ram problems.
Windows 98 won't even support over 500MB anyway!
Mike Washkevich http://www.nowherequick.com http://www.kellyiris.com http://www.progressivestudios.com |
I have read here that Windows 98SE works best with 256 megs RAM. Windows 98SE is optiminizied to work best with 256 megs and anymore will actually decrease efficiency with PTLE and a default Windows 98SE install.
You can actually add more but there are system tweaks that would have to be done, and I have no idea how that's accomplished. Hope this helps. [img]images/icons/smile.gif[/img] |
Check these links out. There are work arounds for adding large amounts of RAM to your system. The question is, does PTLE take advantage of more memory or does it tax the processor the most. I suspect that adding more memory won't necessarily help with PTLE because I've never had the system run low on memory but Ihad it tell me that it's running low on processor power. I'd spend my money on a faster processor, if applicable. http://support.microsoft.com/support.../Q253/9/12.ASP
ASUS A7N8X-E Deluxe MD Athlon XP3200+2.20GHZ Corsair XMS PC3200 400MHZ 1GB WD EIDE 10GB WD EIDE 250GB XP Pro SP1 ProTools LE 6.4 |
Here is a past thread on the topic that may help.....
http://duc.digidesign.com/cgi-bin/ub...&f=32&t=002029
rh music |
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:<HR>Originally posted by nqmike:
Windows 98 won't even support over 500MB anyway!<HR></BLOCKQUOTE> Yes it will. I've been running 512 with no problems. |
Thank you for all the responses. I am reading them all and will use the information as I can.
A Mac thing.. | lemix | Pro Tools TDM Systems (Mac) | 6 | 01-26-2006 11:21 PM |
one thing after another | june bug | Pro Tools TDM Systems (Mac) | 5 | 03-18-2003 11:25 AM |
the thing about the 002 is... | neil_mcdermott | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-18-2002 03:42 PM |
Okay, almost there...one last thing with Bus | Timothy72 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-08-2002 10:57 AM |
and another thing... | miotch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-25-2001 10:54 AM |
