Old 08-12-2011, 11:08 AM
sunking3 sunking3 is offline
Default Pro Tools 9 and Windows 7 32bit
I have PT 9 working on my Mac Pro however I have installed PT 9 on my PC with Windows 7 32 bit and when I try to startup it says that my hardware is not connected. I am using a Digi 002 mainly but I would also like to alternately connect to a Midas Venice F16 when I am not using the 002. I downloaded the ASIO4All and was able to get the session to open but I do not see the Digi002 show up under hardware. I have downloaded the drivers for the Midas console and the 002 but I am unable to select them with good results. Any suggestions will help.
Old 08-12-2011, 11:41 AM
daeron80 daeron80 is offline
Default Re: Pro Tools 9 and Windows 7 32bit
Remove ASIO4ALL and see if the other two show up. It works for some people but has been buggy for most.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 08-14-2011, 04:42 PM
I finally got the Midas F16 to talk to PT 9. I see it under hardware setup but when I go into i/O setup it still has my Digi 002 and ADAT lite pipe settings for I/O. I can work around this, I know that I can re-label and the channels correspond to those of the Midas however I am having a devil of a time trying to send from the auxillary buss on the console, via firewire, into an effect plugin in PT 9. I have a call with Midas tomorrow that will hopefully solve this issue. Thanks for the help and I will post the answer to my query.
Computer reboots at Pro Tools LE 8.0 startup (Windows 7 32bit) jobo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-04-2011 01:40 AM
How To Install Pro Tools 8 on Windows 7 32bit hendrixrocker2 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-19-2010 06:54 PM
Mbox2 Windows 7 32Bit blace160 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 03-22-2010 10:21 AM
Getting Pro Tools 8 to work in Windows 7 32bit - Digi002 (what worked for me) DeyBwah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-11-2010 02:39 PM
Installing Pro Tools 8 on Windows 7 32bit Promblem illbeatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 22 11-02-2009 12:27 AM
