Fades behaving badly.
Yesterday I was doing a session with regions with fades at the end. For some reason I cannot find the answer but the fades don't sound right. If I double click the fade to bring up the fade dialog box from which to choose various different fades the preview button plays the fade as expected but when I go back to the edit page it doesn't behave properly. Is there a setting somewhere or has anyone had this happen to them? I had a client watching me try to sort this out and I couldn't find the answer. My work around was to use automation. Not the most practical of solutions. BTW before that I had all automation turned off.
Re: Fades behaving badly.
Also, post your system specs. Read the "Help Us Help You" thread if you're not sure what to post. |
I already included my spec in the About me page but for some reason it doesn't show up in the thread.
Anyway you're right more specific is what's needed. The fades are decreasing in volume but not as quickly as they should. ie by the end of the region the audio is still audible. I've tried various shapes but they all do the same in this particular session. My specs are Mac Pro 2 x Dual 3 Ghz Xeon 8 GB Ram OSX 10.6.7 Pro Tools 9.0.3 Apogee Duet. |
They get messed up once in a great while. Probably a disk hiccup rather than a program bug. The quickest fix is
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
Depending On Whether You Have "Elastic Audio" Selected For Those Tracks, The Fades Will Sound A Little "Off".... You Need To Render Your Tracks By Turning Elastic Audio "Off" And "Committing" Once, You've Finished Editing...(Elastic Audio Takes Up A Ton Of CPU Power) Of Course, If Your Fades Are Sounding "Bad" Without Elastic Audio... That's Another "Long" Story... Bump Up Your Cache.... Turn Off Low Latency Monitoring, Make Sure Your Fades Are Long Enough/But, Not To Long.... Sorry, If This Isn't Much Help....
OK I've tried trashing the fades folder and regenerating without searching. made no difference I'm afraid. I suppose the best way to describe the problem is that the fade is not happening at full strength. Meaning when it reaches the end of the region it should be at 0db almost at the end and tail off nicely. What I'm hearing is audio right to the end of the region.
I am also not using any Elastic audio. Just plain old audio regions using the standard fades from within Preferences. Although the preview does play the fade correctly. That's what's confusing me. |
That's a new one. In the words of a former employer of mine, "Nobody ever broke one o' them before."
That is strange Huh?
Just off topic how do I get my specs included permanently in all my threads?. They are there when I click on my user name but don't seem to appear as yours does. Any tips? |
Edit your signature
Here I am, after time not long... and thankful for the break, What I found when I got there, was that I couldn't stay away! Hobo Shave! |
Elastic Audio Behaving Badly | Analog Kid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-28-2012 10:36 PM |
Disk Allocation not behaving? | umb | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-15-2007 10:55 PM |
Strike Not Behaving | digijohn | Virtual Instruments | 5 | 05-03-2007 11:39 PM |
plug in help needed badly, very badly | brentjd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 03-28-2006 05:37 PM |
how is your 9.1 behaving ? | TRIRATS | Pro Tools TDM Systems (Mac) | 1 | 05-03-2001 02:20 PM |
