The Omni's I / O limitations
So I am thinking about adding one of these units to my current HD IO 8 x 8 x 8
So the maximum inputs I can stream into the Omni into ProTools is four analog inputs as I understand it Just wanted to make sure that there is no limits or restrictions on the outputs. Another user gave me the idea to use the analog outs for headphone feeds.... And I just want to be sure there is no restrictions on the outputs. I'll be able to use all of my outputs across both interfaces? I was reading the manual last night and it said the max inputs was limited but I didn't find anything talking about the max output limitation
Re: The Omni's I / O limitations
Yep, used omni as a Monitoring control, and extra 8 outputs for pushing individual HP mixes
$800 - sweet deal. Have you seen the prices for the 8 Analog Output cards for the new IO's? Make an Omni for $800 seem easy
I agree, at those used prices, they are a great addition to many people with a Digilink stack.
Keep in mind it's 8 outputs total. If you are using 2 for your stereo monitoring, then you only have 6 outs left. It's not stereo monitor plus 8. The TRS jacks simply mirror 2 of the outputs, as a convenience so you don't have to have a DB-25 cable.
One alternative is to use your adat outs on the 8x8 with something like the Behringer Powerplay system. |
Duly noted, I will look at the power play units....thanks
Is anyone still reading this thread?
I’m finally diving into using this as more than a simple stereo analog i/o. The hardware setup menu confuses the **** out of me. I’m not embarrassed to say so. I have some hardware (reverb and converter) that I’d like to connect via AES or ADAT. I ONLY need a stereo analog i/o. Has anyone mastered this unit? I could use some help/guidance. Thanks.
AQ. Mac OSX Mojave 10.14.6 running Pro Tools Ultimate 2023.6 Mac OSX Mojave 10.14.6 running Pro Tools Ultimate 2022.9 Black Lion modified OMNI HD w/XB clock Multiple Black Lion modified 192 FM/XB interfaces Mac OSX ML 10.8.4 running PT10.3.7 HD4 PCIx (TDM & Native) |
Well, after many hours of patching and repatching both analog and digitally I’ve realized this unit has some serious i/o limitations all based on the convoluted hardware setup.
And incredibly pour metering. It’s too bad. I had Black Lion modify it and it really does sound good now. Before, not so good. Live and learn. C’est la vie. Gonna sell it and find something else. Maybe a Lynx Aurora?
Limitations | ivet | Windows | 1 | 01-05-2013 05:58 PM |
What are the limitations? | Terry Wetzel | Windows | 21 | 08-08-2012 08:56 AM |
OMNI Fried? Calling Omni Members - Check High Samplerates | KingFish | Pro Tools TDM Systems (Mac) | 3 | 11-03-2011 09:19 PM |
Be aware! Potential HD Omni buyers with treated Rooms and Computers. Omni Noisy Fan | FRaNCo MuSiC | Pro Tools HDX & HD Native Systems (Win) | 0 | 09-25-2011 05:42 AM |
OMF limitations | Fritz | Post - Surround - Video | 6 | 10-06-2005 09:25 AM |
