Old 06-10-2021, 08:13 PM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
Default D-Control Main unit no lights
Hey all.
Earlier this year I had to replace the LED PSU on the fader unit.
And few months later fader unit leds and the main unit leds started flashing. And then Main unit leds died completely, including talkback, oleds, everything.
However, the unit kept working as normal, buttons worked.
Today I replaced the LED PSU on the main unit but the lights didn't come back...
(Fader unit LEDS came back after the replacement)
At the moment I am anxiously waiting for the courier to bring me the Logic board PSU to see if that helps.
My hours are counting fast towards an inoperable suite, so any insight is much appreciated right now..
cheers
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
Old 06-10-2021, 10:11 PM
Vedat's Avatar
Quiet Art Ltd.
Default Re: D-Control Main unit no lights
OK, so here's an update.
The new LED PSU works only if the heatsink is not connected to the chassis. Which I find weird as it's an identical replacement.
But I am nervous about not connecting the heatsink to the chassis as the regulator might overheat.
Any technical minded peeps here that could shed some light?
Vedat
QuietArt.co.nz
Catchin' SYNC app
Old 06-13-2021, 05:30 AM
LDS LDS is offline
I can't speak for the D-Control specifically, but if you ground a regulator's heat fin it will often cause it to stop working. It usually needs to be electrically isolated from ground. It is an easy thing to do with small PCB mounted ones that have a heatsink that just floats in air, but for bigger chassis mounted heatsinks, you usually need an insulated heat pad between the regulator and heatsink, as well as some consideration about how the nuts and bolts keep them both together. Often there is a small plastic washer on the regulator side to prevent metal on metal contact. I always seem to mess it up though, as the bolt shaft can still make contact. I usually use plastic nuts and bolts which work quite well.
It might be a case that you need an insulated heat pad between the heatsink of the PSU and the chassis. They also often get called thermal gaskets, and are a sticker on one side. Peel it off, stick it on, and press it all together.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command.
Old 06-13-2021, 03:39 PM
Vedat's Avatar
Quiet Art Ltd.
So, I figured out the issue. On the old model PSU they used isolators to connect the regulators to the heatsink bracket on the PCB. The new ones don't have isolators. Quite the design flaw if you ask me. I used silicon isolators and plastic sleeves for the screws to mount it on the chassis without connection.
All is good!
Vedat
QuietArt.co.nz
Catchin' SYNC app
Old 06-14-2021, 06:42 PM
arche3's Avatar
arche3 arche3 is offline
Great info! Thanks
Sent from my SM-G986U using Tapatalk
Pro Control - Main Unit Dopamine Buy & Sell 0 06-08-2021 12:04 PM
FS: Pro Control Main Unit Echo studios Buy & Sell 3 10-01-2018 04:48 PM
FS: D-Control Main unit PTPerson Buy & Sell 1 02-08-2017 09:59 PM
FS (EU) Pro Control Main Unit Vytis Buy & Sell 1 01-07-2016 06:36 AM
Pro Control Main Unit is intermittent tekis ProControl, Control|24, Command|8 2 07-31-2014 01:18 AM
