Old 03-05-2003, 07:58 AM
lcouri lcouri is offline
Default peak master- where, doc, kickin, chompers, et al ...??
For those of you who do a 'junior' mastering on PTle: I am finding the peaks of individual songs using the Audiosuite gain plug, then using the L1+ to up the level close to zero. The resulting song is then put through an L1+ on the master fader (preceded with a C4) to get a final composite of songs with close output levels ... is there any comprimise of sonic quality here?
Thanks
002R; G4 Powerbook 1.5Ghz 1GB RAM OSX 10.3.4
Firewire 800 external drive
001; G4 533 1GB RAM OSX 10.2.8
Old 03-05-2003, 09:11 AM
Slim Shady Slim Shady is offline
Default Re: peak master- where, doc, kickin, chompers, et al ...??
In my opinion, it's never a good idea to use two L1's on any track/song. One instance on the master fader or in a separate mastering session is fine, but I've noticed that anytime that a track or song has been effected by two L1's, it gives things a very strained and thin quality (with too much bass boost as well). It could be a cool effect if you're going for it on purpose, but otherwise I would try to avoid using the L1 anywhere other than in the mastering stage of your song.
Again, just my opinion [img]images/icons/smile.gif[/img]
Old 03-05-2003, 10:10 AM
Thanks, that's good to know ... I'll keep it in different sessions ...
Old 03-06-2003, 05:23 PM
Doc Doc is offline
I generally agree with Slim on multiple instances but there are exceptions though.
For example, a mix I am finishing now has a thunderclap at the end that I want to create some impact. I put an L2 on that channel and pushed it a few dB for added punch without needing to sacrifice the level of the rest of the song. The final master of the album this track is from will probably have an L2 on it too with minimal or no gain.
Something else to consider is whether you want all tracks normalised (maximum level without compression). Quite often the level your ears perceive and what the meters tell you is quite different. This is partly due to the non-linear sensitivity of human ears and the varying frequency content of different songs. My advice is to trust your ears and adjust levels to suit.
Also, it is my opinion and indeed the opinions of most other mastering engineers that less is usually better. Get it right before mastering. The best compliment you can get is for the mastering engineer (or you if it's a DIY) to say, "I don't need to do anything to that".
Old 03-06-2003, 06:16 PM
thanks doc, i appreciate your thoughts!
Old 03-07-2003, 07:22 PM
luvmixnhigh luvmixnhigh is offline
Does it sound good to you?
This is the only question.
I prefer to mix the final with nothing on the Master. Sometimes I will leave DUY Wide but, no limiting. Then I send it our for mastering. If the band wants a hyped CD I spend 5 minutes with Wide,McDSP, and sometimes L1+ on the end. I prefer to not use it if I don't have to. It seems to effect imaging to me..?? I could just be crazy but, when I hear my mixes squashed with L1+ they almost sound mono-ish, thin, I don't know how to put my finger on it OR describe it but, I don't care for it. Mosy clients don't hear it so I use it.
D
Old 03-08-2003, 05:19 AM
Doc Doc is offline
luvmixnhigh,
Hypercompressed mixes can sound very thin and 'mono-ish' particularly when pushed too far. Personally, I don't like hypercompression at all so, for me, 'too far' is not very far at all.
Also, when taking your mixes to a mastering house, consider not using any imaging plugins (DUY Wide, Waves S1 etc.) or at least providing an alternative mix with nothing at all on the master fader. The engineer will thank you. [img]images/icons/wink.gif[/img]
Master Track & Input Track LED peak when record enabled sharptoothyouth 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-20-2009 02:11 PM
Does a red peak on a track mean the same as on the Master bukman Tips & Tricks 2 10-02-2007 11:13 PM
Levels Peak on Master Fader NonSpecific 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 07-09-2006 04:56 PM
Have you tried "Peak Master"? poppy Pro Tools TDM Systems (Mac) 0 01-11-2004 03:37 PM
Peak levels on Master fader during mix. Hardnox Tips & Tricks 7 11-05-2001 08:59 AM
