Best Way to bounce tracks with effects/plugins
Hey All,
Using PT 6.2. Running out of DSP and need to bounce effects/plugins to free up DSP. Whats the best way? Use the Bounce To Disc function under the File menu? Bus the track to another? Set output of one track as input to another? Using bounce to disc and bus method seems to raise the volume higher than the original. Have tried seraching the DUC, but the search is not working it keeps returning all posts starting from most recent. Thanks all |
Re: Best Way to bounce tracks with effects/plugins
If your volume of the is set to unity 0 , your volume should reamin the same as you print it( bound to disk) make sure you assign all tracks and effects to bound and mute all other tracks. Also make sure you have removed any Master Output insets, as they will effect your bound level and sound. Check Import after bounce and you should be OK. Spot it and it should return to the original time stamp, if not uncheck auto spot regions and repeat the same.
Later, Kurt [email protected] Intel duel Quad core PT 8.0cs3 HD4 D Command / D control |
also, if you bus to another audio track and print, you aren't really bouncing to disk and you will have a 10 ms offset to deal with, by nudging the track ahead 10 ms you will remain fase locked, I prefer to bounce , that way there is no timestanp difference.
STeve
macmandigital.com |
even with ADC ?
STeve
macmandigital.com |
my bad, sample is correct!!
Effects Bounce. | tommydigiowen | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 05-08-2011 07:48 PM |
bounce with external effects | karaho | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-03-2008 09:08 AM |
Adding effects during a bounce | GtrDude | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-20-2005 10:02 AM |
Bounce to Disk, No effects? | geordieboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 05-06-2001 08:31 AM |
Outboard effects don't bounce to disk? | Kerry C | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 11-08-2000 12:54 AM |
