Axiom 49 instrument midi issues
I am trying to record some midi type stuff.
I have an Axiom 49. I installed the drivers. I checked the midi inputs. It shows Axiom 49 in1 and in2. I created an instrument track. I tried it with tick and samples. I inserted sample tank free. I picked a piano sound. I then selected the record button on the mix window. I play the keyboard and I don't hear anything or see any signal. I created a separate midi track and selected record and I can see the signal coming in, so I know the signal is there, but I am trying to do an instrument track to use sample tank. Anyone have any suggestions how I can get this to work. My keyboard says it is set to channel one. On my input for the track in the mix window, it has all channels selected. I tried with channel 1 and it made no difference. |
im using a mac. i also have samp tank and an axiom 49...have you tried opening sample tank as a stand alone? if not, do so, and select "settings" ...at the prompt, make sure midi input is selected to "usb axiom" ...does the axiom play now? if you dont have stand alone...try using another midi instrument. try
http-//www.linplug.com/Download/download.htm.webloc its a free linplug alpha....its nothing genius but may help trooble shoot to see if it is the sample tank not working....i say this because many of people i know using samp tank , mini moog, and mirorslav, have issues of finding the istruments in folders...also check the default midi volumes on your axiom....there are the faders. one usually controls overall instrument volume. im no midi expert but ive had some of the same issues and now love my axiom...good luck .let me know if that works...cheeers |
Thank you so much for your help.
I am a guitar player and not used to the midi world. I am just trying to get as much power out of using pro-tools, plugins, etc. I will try your suggestions. |
I don't see an exe to kick off Sample tank as a stand alone application.
How do you open it in standalone mode? I have the free version or lite, I am not sure if it can run standalone. |
hmmmm not sure...im a guitarist myself.lol i just happen to have those products... did you try the linplug? just to see if maybe its just samp tank? if you are on a mac....go to... mac hd, to " library" to "application support" to " i.k. multimedia" to "sample tank my list under smple tank is as follows...
folder: effects folder: images folder:instruments etc..... im not sure if this is because i have the stand alone....but do you have instruments in the "instrument folder? they should be there.... try this also .... mac hd to"library" to "audio" to "plug ins" to "vst" .....does it show up? also mac hd to " library" to application support" to "digidesign" to " plug ins" ....is it in that folder? |
i can also send you screen shots of what my setup looks like per folder....i know this can be confusing sometimes...anyway feel free to contact me direct. cheers!
oh yeah ....good point....make sure your track is stereo....dont think samp runs mono....oh wait , but you did say you had it open? holla!
I will check it out with Xpand.
Kind of tight on time right now. Will let you know after the weekend. |
Instrument tracks don't recognize Axiom 49 inout | tdawgg | Windows | 0 | 06-20-2013 05:36 PM |
M-Audio Axiom Pro doesn't send data after changing instrument | Chingy | Pro Tools 10 | 8 | 12-31-2011 08:14 AM |
Axiom Pro issues | gdugan | MIDI | 1 | 03-11-2011 01:40 PM |
Axiom Pro 25 and Instrument/plugin parameters | clausiii | MIDI | 2 | 06-03-2010 02:52 PM |
Axiom 49 midi recording issues | drewlyddon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-04-2009 07:02 PM |
