Old 03-30-2021, 03:35 PM
Chris August Chris August is offline
Default Elastic Audio Pitch Shift Not Working
I select a clip - I turn on Elastic Audio in Polyphonic mode - I open Elastic Properties - I type in -2 in pitch shift - nothing happens. It just resets itself to 0. I've watched multiple videos and I'm following each step. Is there a setting somewhere that I'm missing?
I'm currently on the new update, but I've never been able to get this to work. I always end up having to use Serato Pitch n Time... figured today was the day for me to figure out what I'm doing wrong.
Thanks!
Chris
Old 03-31-2021, 05:25 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Elastic Audio Pitch Shift Not Working
When turning EA on, open task manager to view the process.
Once the process is finished your pitch and time elastic audio will work.
If not the greater detail on you system may be needed.
Check your session drive record/playback status.
Note that tick/midi or timebase will respond differently.
Old 03-31-2021, 06:45 AM
midnightrambler midnightrambler is offline
Thanks!
Chris
It doesn't sound like you're doing anything wrong from what you've said. Tried trashing preferences? Or maybe a clean install. Sometimes Elastic does weird things that only seem to happen on one machine. (I had one where I had to keep pressing "save" before it would analyse the audio, no one else seemed to have the problem. I had to get an Avid guy to take over my computer and trash a load of files that were goodness knows where.)
Old 03-31-2021, 08:18 AM
Yeah for some reason it just isn't working for me. Tasks done.. clean install.. I'm actually on a temporary machine while mine gets fixed and it does it on this one too. Both machines, same problem.
I submitted a ticket with Avid so we'll see if they can help.
I appreciate the input!
Old 03-31-2021, 03:02 PM
Hmmmm, it seems fine here(just tested in both Ticks and Samples).
Can you automate the Elastic Audio Pitch shift on Audio tracks? DBK Getting Started 3 11-07-2014 03:38 PM
BUG: Elastic Properties Pitch Shift AAE error -9411 adrianrobison Pro Tools 11 1 08-28-2014 02:51 AM
Elastic Properties Pitch Shift Value not Retained anklescrape Pro Tools 11 0 06-29-2013 10:04 PM
Pitch Shift VS. Elastic Pitch StinkyStan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 08-24-2009 09:15 AM
How Do I make Elastic Pitch shift gradually? products7074740 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-03-2009 03:43 AM
