Old 09-17-2009, 08:15 AM
trock trock is offline
Default the quality of just the 003 rack?
Hi all
I have hemmed and hawed around for a long time about moving to PT LE and finally saw it at a friends in action this week
i fell in love with the look and layout
that being said, i come from Cubase 5 on a mac pro 2.8 octo, 16 gigs ram, 4 HD's, 3 500 gig spres and the system one etc
running 10.5.8
i have a big home setup based around cubase, yamaha N12 etc
that being said, i have scoured this site for feedback on anyone just using the rack for AD/DA and not worrying about an apogee or lynx etc
for a home guy doing quality demo's of his songs do you think the rack AD/DA is pretty good? the n12 is very good, better than the RME FF 800 i had so while not an apogee its AD/DA is quite good.
when we talk about an apogee 800 into 003 are we talking a 5% or so diff?? know what i mean or a huge one??
i am very new to PT even though i saw my friends on his 002r and 8.0.1 but that sounded pretty good to me
is the 003r a pretty big step up? or small?
would love to hear from you who are just using the 003rack for AD/DA
i have a host of quality pre's i am going to insert for my front end
Pendulum Quartert
LA 610
Sebatron thorax etc
thanks for any feedback
Old 09-17-2009, 08:44 AM
suitelounge suitelounge is offline
Default Re: the quality of just the 003 rack?
Here is my feedback.
I used to have a 002 and an MBOX2 Pro, and now have a 003
I have used Apogee converters in front of the 002 (and I also have an Apogee Duet that I use with Logic). Apogee makes great products, and they will definitely add something to your recordings. If you like their sound (they do have a sound) by all means go for it.
There are really two components to consider on the 003, the converter (and the clock), and the pre's. (If you are COMPLETELY bypassing the pre's and using your other ones, then it's just down to the converters).
Are you capturing a great sounding source? How does the ROOM sound? Is the VIBE there? Are you happy with the end result? To me, these are more important than what converter you used. I say, for a home setup, you could do a lot with just a 003 (especially with some nice pre's in front). You will never look back and say, "this really sounds great, but I should have used other converters because that's what everyone told me to do," or "they would improve the quality of the sound x %"...if it sounds good it is good.
If you like the idea of using Pro Tools, the 003 can be a great tool. You could always use it, see how you like it, and add an Apogee, or other, later, just like adding another mic pre or other piece of outboard gear to compliment the setup, sprinkle in some flavor, etc.
Good luck
Old 09-17-2009, 08:53 AM
thanks for the answer
i think i am going to just get the 003rack, and the Musicians toolkit 2 for the additional tracks. keep it simple like you said
then once i really know it make a decision
i tend to dive in and makes things really complicated at first and get confused
sounds like the rack is pretty simple to set up and get going, then of course i need to learn PT and that will take a while :)
thanks for a straight up answer to
Old 09-17-2009, 09:39 AM
You also should ask yourself if you need a control surface. If you do, you might consider getting the Digi003 instead of the Digi003R. This will save you the trouble of finding a separate control surface like the Command|8 or something from Euphonix, Mackie, etc.
Also ask yourself if you want to have 4 Digidesign mic pres or 8 Digidesign mic pres. The Digi003R has 4 and the Digi003+R has 8. The Digidesign mic pres are relative neutral and transparent. In otherwords, there is not much coloration but at the same time I don't hear people raving about how great they are either. There are many delicious mic pres available to add color or to keep thing as pure as possible if you like.
As for the converters I agree with the previous post that the room and acoustic treatment make more of a difference than the converters. There are obviously better converters out there (for more $) but with any modern interface, the converters are very usable and pretty good already. If you go with Apogee or something like that, keep in mind that it will probably be connected via the ADAT 8 channel optical inputs which are limited to 48KHz (no SMUX support to get 4 channels at 96KHz).
Obsidian Dragon
Mac Studio M1Max - 64GB
Old 09-17-2009, 10:08 AM
rainsong rainsong is offline
+1 for the 003 control surface. I use mine every day.
Although there's one or two functions that I wish were on there, I'd hate to be without it at this point.
2010 6-core Mac Pro, 16 GB RAM, OSX 10.9.4, PT 11.2.1, RME Fireface UFX
2014 i7 4-core 15" MacBook Pro Retina, 16 GB RAM, OSX 10.9.4, PT 11.1.2
Old 09-17-2009, 10:24 AM
jakas jakas is offline
Smile Re: the quality of just the 003 rack?
Hi guys,
I'm a pro user with a HD accel rig in studio.
I bought a 003 rack+ for some on-location recording.
I done a 8 track recording with Richard Galliano, PT8LE on a MacBook Pro 2,33 at 96 khz, Waves Gold plug ins, good mics, very good room (a theatre in Paris).......They used the rough mix for the final production and sound more that great!!!! I love 003 rack+. My opinion is that works very well, neutral, good quality/price. I know very well that there are a lot of better preamps and converters, but with a good musician, good mics, good room and know where put the mics, all is done!!
I suggest that 003 rack+ is a good device.
Ciao
Old 09-17-2009, 12:34 PM
thanks so much guys, i am far less worried about the AD/DA now
as for the other questions, i have thought about my setup and have come up with this
Control Surface - Mixed logic M24, i have this and have used it with cubase, sonar, logic, and samp. i have also confirmed with the company it works with PT8 set up as 3 HUI's and actually has alot of functionality. although i mainly need faders, mute, solo, record, pan etc the basics
www.mixedlogic.com
my total setup is this and how i am thinking
Triton Pro - into Pre's 1-2 on rack
Fractal Axe - Pre's 3-4 on rack
Quartet - insert 5
610 - Insert 6
Thorax - insert 7
so for me, 4 pre's does the trick
i keep worrying about ADC since i use
RMX
Waves SSl, Maseratti, Native
SD2
Addictive drums
CSR verbs
etc
but it seems it just takes some time to compensate and adjust tracks, worrisome though in terms of mixing and creativity coming to a halt?? thoughts?
thanks for all the help to.
my room is well treated and i have some nice front end gear and mics. so i think i am all set with the 003rack, MKTP2?
anything else that stands out to you guys that i might be missing or configuring wrong??
oh are there setup instructions for programs like superior drummer 2, RMX and Addictive drums for PT? and do they work well in it?
Old 09-17-2009, 12:54 PM
flommer flommer is offline
The mixed logic looks like a pretty good deal..
Check this out though... Droolworthy...
http://www.mercenary.com/smartav.html
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 09-17-2009, 12:56 PM
oh yeah the smartav!! man those are crazy! would love to have that and the extenders! wayyyyyy out of my price range though :)
Old 09-17-2009, 01:11 PM
peppertree peppertree is offline
There are only two pro tools interfaces that make sense right now, and those are the M-Audio 2626 and the 003 Console. The 003 Rack and 003- Rack are total wastes of time. The Mackie 1640i will be a third option that makes sense as well when it arrives.
The 2626 has the best AD/DA of everything mentioned, has the lowest latency cue mixing (other than the 1640i straight analog), runs 26i/o and all 18 @96KHz, and is the cheapest and smallest.
That said Digi feels a need to cripple it beyond the 003, denying it the inComplete Production Toolkit and limiting the buffer to 128 samples, limiting the i/o to 18 because they would have no means of moving the backlog of 003 units rotting in their warehouses otherwise.
All things told I don't think Digi has earned new business and I would suggest moving to Logic until they get their act together.
`My name is Pro Tools HD, King of Kings:
Look on my works, ye mighty, and despair!'
Nothing beside remains. Round the decay
Of that colossal wreck, boundless and bare,
The lone and native DAWs stretch far away.
Very low sound quality when recording with Eleven Rack dbvoyager Eleven Rack 15 05-29-2013 05:27 AM
Eleven Rack preamp quality? petmar Eleven Rack 5 01-15-2012 07:06 PM
Eleven rack AD-DA quality hollow Eleven Rack 16 03-27-2011 11:21 PM
Analog audio quality of 003 Rack bblue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-20-2007 07:31 PM
High Quality Pre Amp for 002 rack? Mason00 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-31-2005 08:59 AM
