Old 01-04-2022, 11:17 AM
gwbigfish gwbigfish is offline
Default Sonarworks Reference plugin
Anyone here using this plugin? The plugin is supposed to "neutralize" the frequency response of your headphones or speakers which leads to a more balanced mix result. Before bouncing down the mix though you have to bypass the plugin which in my mind defeats the purpose of using it in the first place. The sound is completely different with the plugin bypassed. Appreciate any thoughts you might have
Old 01-04-2022, 11:21 AM
Sardi Sardi is offline
Default Re: Sonarworks Reference plugin
If you don’t bypass the plug-in, you’re rendering the EQ curve to your audio file. That means those changes it’s made to correct your room deficiencies would be permanently rendered to your audio.
Old 01-12-2022, 10:37 AM
indeloon85 indeloon85 is offline
Check out Rogue Amoeba's Soundsource. I use sonarworks but not within the session. I will use in within Soundsource which allows you to monitor the plugin and bounce the material without the plugin affecting the outputs in Pro Tools.
Old 01-12-2022, 05:50 PM
Or you could just set up your Pro Tools session accordingly and use a seperate monitoring buss and not select that when bouncing your audio.
But that’s not what the OP (who seems to have vanished) is worried about. They don’t seem to understand the point of the correction.
Old 01-12-2022, 09:49 PM
hahaha! Good point
Old 01-19-2022, 06:31 AM
MrDibS MrDibS is offline
One thing to note about even having a second monitor bus:
This will induce latency (even a bit on zero latency mode) and will require turning off delay compensation or deactivating the plugin when recording even though it is not in your main output bus.
I just thought it was worth mentioning. It’s the kind of path you add to your setup without thinking about the latency and then wind up pulling your hair out later.
Mac Pro 2013 12 Core Trashcan, 64 gigs, OSX 10.14.6
PT HD Ultimate 2021.12 HDX with Focusrite Red 8pre, Rednet 2, R1, Dock + S3.
HTML code is On
Sonarworks Reference problem Danny_79 AAX Plug-ins 18 05-28-2023 07:50 PM
Sonarworks Reference 4 - Digi 002r Issues Nish FireWire & USB Audio Interfaces (Win) 11 07-25-2020 10:33 AM
FS: Sonarworks Reference 4 $145 crandallwarren Buy & Sell 1 05-24-2020 06:46 AM
AAE -30001 error w/ Sonarworks reference 4 stephen.r.banville Pro Tools 2019 11 10-17-2019 07:32 AM
Sonarworks Reference 4 ASIO Wawili_Sound Pro Tools 2018 2 01-22-2019 11:58 PM
