Old 05-20-2011, 08:09 AM
cwholden cwholden is offline
Default PT9.02 & macbook 2ghz intel i7 crash
macbook 2ghz intel core i7
4GB ram
OSX 10.6.7
PT9.02 (re-installed and updated drivers)
I'm able to launch PT & suddenly have the session crash. No particular key stroke or repetitive pattern causes the crash- just crash.
Any know issues with i7 & PT9.02?
I know the HD is @5400RPM-however I've been using external FW800 WD @7200RPM and still crash.
Old 05-21-2011, 08:02 AM
Default Re: PT9.02 & macbook 2ghz intel i7 crash
Kernal panic also comes up.
I've attempted smaller sessions and larger sessions,
from internal to external drives; with and without
audio in the session.
Same outcome.
Crash and kernel panic.
There's no crash as long as I don't touch the mousepad or keyboard- however
once I touch something- immediate kernel crash.
Old 05-21-2011, 10:50 AM
handersson handersson is offline
Same outcome.
You got me really nervous there... I have just finished all the installations except my Eleven rack drivers on my brand new MBP 15" 2.0 Quad i7. I was just about done when I thought I would do a last check for updates etc. (PT, Reason and a lot of sample libraries.. hours of installations)
Then I saw this...
But something must me wrong cause everything is working fine here. I just opened Pro Tools and started a session on my system drive without any external device. Works perfect so far.
- You do have your ilok inserted into your Mac right???
- Have you done the optimizations for PT? Some of them, if not all, might be necessary for stability.
Your Airport is not activated?
Long story short... this should work!
Hope this helps.
/H
http://www.handersson.se
Old 05-21-2011, 11:04 AM
My authorization from the ilok has PT9 HD on it.
(brand new upgrade purchase from HD7.4 surrender license)
An associate suggested that the difference between HD and just 9 could be the problem...
Is a MacBook Pro 2.2Ghz okay for PT 8? Monaco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-04-2009 04:40 PM
macbook pro 2.2Ghz merman1983 General Discussion 4 11-18-2008 02:06 AM
Macbook Pro 2Ghz Intel Core Duo V8Vantage 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-21-2008 03:47 PM
Apple 2GHz Intel Core Duo LaForestPoetry18 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-16-2006 08:40 PM
INTEL P4 3.2Ghz Extreme Edition Abomb97 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 01-22-2004 01:40 AM
