Import Midi File first and then audio tracks or vice versa?
Hi everyone,
I have a client that works in Digital Performer; when those files come into our building, they go into ProTools. So, he sends us a MIDI map with markers, tempo, etc. AND, he also sends us audio tracks. Should we import MDI first, AND THEN the audio files? Or vice versa? Or does it matter? Anyone know? The reason I ask is that when we then export as WAV files back to him, things aren't lining up perfectly. Any help would be greatly appreciated! John |
Re: Import Midi File first and then audio tracks or vice versa?
Audio is more accurate than MIDI.
He/She should be sending you also a click track as an audio file (where you know the first audio click is bar 1/beat 1 or from wherever he/she started their MIDI export from)
You have to do all of that.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Alternately, instead of sending files, have the DP system export as OMF or AAF and then import everything in one shot. Another option would be to have the DP user print their midi instruments to audio and send you all audio tracks
OMF/AAF do not transfer tempo/meter/midi data. That's the important part. And most likely the audio files are the printed midi instruments. But you still need the tempo/meter map. Which only comes from another DAW via MIDI. This is also a bog standard process that we've been doing in the film/tv scoring world for over 20 years. Some DAWs are better than others (and even versions of DAWs have differences) because MIDI export isn't as standard as it should be. But there are ways (sometimes slow, manual ways) to correct.
Kerry Smith http://apothekerry.com Mac Studio Ultra : 128GB RAM : Ventura 13.6 : Carbon : PT Ultimate 2023.12 : S1 : Metagrid Pro |
Audio precision is the most accurate choice always.
The audio files in any DAW print to where things were heard. MIDI data is very dependent on the sampler and how samples were cut (or for synths, the envelope). To put it simply, a MIDI “note on” trigger tells something to start. But what is receiving that message could actually produce the audio sound at any point. And a composer is working to where they hear things. Not to when they hit “on”
By default, I would expect someone doing this process would be exporting everything from zero on the timeline. As long as that’s the case, then the import order doesn’t matter. I too would import the MIDI and all it entails first, and then bring the audio in.
If I'm importing separately, I'm going with the MIDI first in order to get the tempo map, then audio falls into place just fine. This also prevents any tick-based audio tracks from being tossed around the timeline erroneously.
In practice, I tend to grab one audio and one MIDI -- so that I can verify that they're playing nicely with each other -- then I go back and grab all the rest. This hasn't failed me yet. Luckily, I tend to work with people who are very well organized and prepared, so issues aren't common. If I didn't know what I was getting into, yeah, I'd go with the process in the paragraph just above. |
Syncing MV 8k w/ PT or vice versa | MookHustle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 09-07-2005 09:52 AM |
Man to woman or vice versa | 2fly | Pro Tools TDM Systems (Mac) | 6 | 05-14-2004 06:51 PM |
L.E. TO H.D. and Vice Versa HELLLLP | Robby Hamilton | Pro Tools TDM Systems (Mac) | 1 | 03-10-2003 05:49 PM |
L.E. TO H.D. and Vice Versa HELLLLP | Robby Hamilton | Pro Tools TDM Systems (Mac) | 0 | 03-10-2003 03:01 PM |
Syncing PT to 2" and vice versa... | PeeTee | Tips & Tricks | 10 | 03-17-2001 01:49 PM |
