HELP ! How to stop auto color new playlists!
Every new alternate take now gets a new color. I would them to have the SAME color until I change the color!!!!
iMac Pro - HDX2 - Mojave - AVID HD I/O x7 |
Re: HELP ! How to stop auto color new playlists!
prefs/display/default track color..none
It won´t work. I´m on 8.0.4.
New colors every new round. A new track will stay gray but when loop recording every new take will have a new color. If not loop recording and I move the last take to a new playlist the region will change color against my will...
I´m goin crazy !!!!
How to stop the auto color disaster in playlist regions! !!!!! As soon as I use the seperate tool the region gets a color!!!! I want them to be grey until I ( yes I will decide myself...) give them a color... is this a bug in 8.0.4 ?
Is there a shortcut to show color palette?
AFAIK there's no shortcut implemented for ColorPalette.
But you can use QuicKeys for assigning one. ....other (more fancy) solution is to get a D-Command/Control and assign it to a User-SoftKey
Cheers, STeff --------------------------------------- MacPro5,1 ; 6-Core Intel Xeon 3,46 GHz, 32 Gig Ram, NVIDIA Quadro K5000 with 3 displays connected OSX10.15.7 Pro Tools|HDX Ultimate 2023.6 HD I/O&192Digital&96&96i I/Os D-Command ES 4xUnitor8 & 2xAMT8 |
Ok... but Quick Keys is a generic OS X application? I can´t find any menu to make up my own key commands in PT...
I’m not sure what you mean by “generic OS X application,” but QuicKeys will indeed allow you to create a shortcut to invoke the Color Palette — and then some.
IHTH.
Andre Knecht We’ll fix it in the shrink-wrap. (Frank Zappa) . |
Auto Set tracks vs. Clips in Color Palette | jschmidtiii | macOS | 4 | 02-19-2014 04:15 PM |
How to stop playlist view from turning all tracks the same color? | ryanstewartguitar | Pro Tools 10 | 0 | 12-11-2012 08:54 PM |
Auto Create new Playlists from 7.x into PT 8 | clusterer | Pro Tools TDM Systems (Mac) | 0 | 06-08-2009 08:19 AM |
Color code playlists "good-poor" | Hype | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-14-2006 07:39 PM |
Auto-named playlists | jpj | Pro Tools TDM Systems (Mac) | 4 | 08-15-2006 05:25 AM |
