Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 01-12-2015, 08:45 AM
mikemouse mikemouse is offline
Default Behringer UCA222 not working in Pro Tools 10
Hi guys! I'm rather new to ProTools so don't shoot me.
I'm having a hard time getting my Behringer UCA222 to work with ProTools. For now I only verify my mixes through my laptops mini jack (DT770), and then I can only check on my monitors after I bounced... I'm using Asio which recognizes the device, but when I play back on ProTools all I hear is *click* every second or something. When I change the playback sample rate then sometimes there is just nothing and sometimes it seems to be playing back but I have no sound. The interface is working fine when I'm not using ProTools.
Any advice? Thx
Old 01-14-2015, 08:01 PM
doubleyou26 doubleyou26 is offline
Default Re: Behringer UCA222 not working in Pro Tools 10
Download ASIO4All. Go through the somewhat simple config process and your UCA222 should work. You may need to run high latency when you configure.
I'm using it on an I-7 Dell laptop, it took a little head scratching but the UCA222 does work with it. I hope this helps.
Old 02-13-2016, 01:18 PM
AlexTz AlexTz is offline
Do you know if the UCA202 should work also? I've been having issues with it, but nothing wrong with any part of my setup as far as I or anybody else can tell.
Behringer u-control UCA222 NEED HELP!! AK47 Madman Windows 4 01-07-2017 12:20 PM
Behringer Xenyx 1204USB not working with Pro Tools jmwilson Third Party Interfaces 3 10-15-2014 07:06 PM
Cannot get Behringer BCF2000 working properly Alvin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-28-2011 03:03 PM
002 - Behringer ADA8000 - how do I get this thing working?? mooby24 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 03-30-2007 03:00 PM
BEHRINGER BCF2000 NOT WORKING WITH PTMP 7.1 valayah Pro Tools M-Powered (Win) 5 06-12-2006 09:41 AM
