Re: Plug-in tips
Scovill's the one who got me started on the thing so I figured I'd ask him. Dave
David Stagl - Mixer | FOH Engineer http://www.staglproductions.com http://www.goingto11.com |
Re: Plug-in tips
Dave,
If you have open Auxes, you can compress from the Aux send and return it to an open FX return which is bused to the same group as the rest of the vocals. Erik |
Re: Plug-in tips
On parallel channels you can dial in the a delay on the one with less latency using the delay knob. Set delay to display in samples, then click in the delay field and use the up/down arrows on the USB keyboard to adjust in one sample increments.
Also, right-clicking on a plug-in thumbnail in the rack will display it's reported latency to help you zero in on the exact amount of delay you'll need to apply to your early channel. -Matt
Matt Peterson Avid Audio |
Echo Farm
I have experienced a problem with the Echo Farm plug-in. Whenever, the tempo is changed in the middle of a song it makes a "glitching" sound. I guess that it has to do with emulation of echo tape units, but it also does it with the "digital delay" module. For some engineers this is unacceptable and they opt for an exteral delay unit.
Is there a way out of it? Are we doing something wrong? And yes Sheldon, a "tap button" on the board would be nice (or even a footswitch). |
Re: Echo Farm
Dave
#16
Re: Echo Farm
[quote
Check the "time ramp" button. Try the different settings for that, and see if one of them works better for you. Dave [/QUOTE] Thank you Dave, I'll check it out. |
Vocal tips and ttrick and the plug ins to use | yourdemo | Tips & Tricks | 4 | 07-08-2005 01:47 PM |
best plug-ins or tips for vocals | phanatik | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-22-2004 12:28 AM |
Automating Plug-In Tips? | ej | Post - Surround - Video | 5 | 12-03-2003 07:05 AM |
any tips on using the delay plug-in? | heartparts | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 05-03-2003 11:45 AM |
Plug In Tips | Jason Locklin | Pro Tools TDM Systems (Mac) | 6 | 01-09-2003 06:42 AM |
