best plug-ins or tips for vocals
doin Hip-Hop here. AT 4030A mic, Digi 002(stock pres), Waves Plat. bund., RNC Comp. and Benchmark DAC-1.
just wanted to know if others are doing good or better things to make their ok soundin set up sound better. right now I track w/ light comp. for peaks comtrol(RNC). edit. C4 into another track folloed by RenComp to level out frequencies. EQ the new track and process if necessary. may L1/2, to top it off. reverb -> delay. any1 else doin something to pro their LE vocal takes? leta brother know. Peace! |
Re: best plug-ins or tips for vocals
sometimes less is more
for a lead vocal, i usually put in a hardware t.c.electronics triple-c (3-band comp) followed by URS N-serie eq to sweeten the vocal sound. then i apply some focusrite d3 compression to tame the vocalist, if (s)he hasn't had a great day if the sound isn't there with these steps, there has clearly been something wrong with the recording process, or that the selected mic just hasn't been a right choise for the vocalist in question. then, i make a vocal subgroup where i route all vocals, and put in the bf76. this is something i almost always do - with rare exceptions - because to my ears it makes the high end very nice reverb/delay is whole another matter, and it depends on the mix on the whole. many times is use the psp84 delay (by www.pspaudioware.com) followed by hardware reverb (t.c.electronics or lexicon). but as i said, these vary greatly because each mix lives a life of its own
try lots of different plugin configs - you wont know how it goes till you try it and every voice will be different - beauty of plugs is you have time you try all the strage things that you otherwise wouldnt do - however you want to give you vocals space in the mix and you can easily use to mnay plugins
as with anything try and capture the sound well to start with so try out different mics |
Tips for using default Plug-ins on Vocals | zac_618 | Tips & Tricks | 5 | 02-19-2014 01:33 PM |
Help/tips with vocals | LongRoad | Tips & Tricks | 11 | 06-06-2009 06:40 AM |
In your face vocals Tips !!!! | jeam25 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-13-2006 07:35 PM |
Doubling Vocals... Tips please! | MaKoRancid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 17 | 12-12-2003 01:03 PM |
Any tips on blending old vocals with new vocals? | Somebody | Pro Tools TDM Systems (Mac) | 5 | 06-07-2000 08:38 AM |
