Project Mix and M-Powered
i am currently looking at purchasing the M-Audio Project Mix to start a small pro tools set up. I have read around on this site and a few others, and i just have a quick question about the requirements to run both the Project Mix and Pro Tools M-Powered. From what i have read i believe that i have the right spec on my PC to run both, but just to confirm: My PC: Dual Core Windows XP CPU 2.80 GHZ Ram 1.48 Ram (this could be upgraded) And the processor is a Intel Pentium D (im pretty sure) im not that computer smart so any help would be great. If my computer will run both items, but i may run into problems, please could anyone give me any advice before i purchase...thank you in advance. |
that should be fine, I would just add some more more ram. I have been using the projextmix for a few months now and love it. I ran into issue this past week with windows service pack3, i couldnt get it to work even with the new drivers. so i went back to service pack 2 and everything is good.
Re: Project Mix and M-Powered
I';ve had a project mix for about 18 months. Its fine for what you need it to be. I have several friends with it as well and everyone seems to have some small problem, like my #1 xlr input gives me some static and my master fader doesn't work, but it seems to work great for everything I need it for. I do a ton of music production so I use the Music Production Toolkit and frequently run 48 tracks - I will upgrade to a larger board someday. As for your specs, definitely need as much ram as possible. Same thing with SP3 - STICK with SP2!!! Make sure you have a compatible motherboard and processor that Digidesign recommends, don't mess with anything else. - Good Luck!
ok cool, thanks for the advice, i have sp2 so thats good, means i dont have to download sp3. Im going to upgrade to about 3gb of ram which should be enough..
Also how can i find out what motherboard and processor i need? is there a place on the support area, i have looked around for it, but i may have gone straight past it. thanks for the comments and advice |
M-Powered 7.3 Project Mix Question | capitala | Pro Tools M-Powered (Mac) | 1 | 05-05-2007 09:15 AM |
Project Mix and PT M-powered | lamorak | Pro Tools M-Powered (Win) | 2 | 09-15-2006 12:00 PM |
M powered Project mix Crashes | dekski | Pro Tools M-Powered (Win) | 5 | 07-20-2006 08:22 PM |
Using Vocalign Project 2.8 in PT M-Powered | GamerGee | Pro Tools M-Powered (Win) | 1 | 03-15-2006 07:15 PM |
Project Mix I/O / Pro Tools M-powered Problem | Merrymaker | Pro Tools M-Powered (Win) | 6 | 12-29-2005 08:34 PM |
