Old 07-14-2022, 12:32 PM
Ben Jenssen's Avatar
Default Folders inside the plugin folder
I thought about this, but never tried it; does PT care if you make folders inside PI-folder and organize PI's the way you want? Perhaps even subfolders? Or does it just load PIs however they are organized? Some PI manufacturers let their installers make folders, so why can't I?
I'll be trying it, but I thought maybe someone had already tried it, and might share their experience.
Old 07-14-2022, 12:40 PM
AlexLakis AlexLakis is offline
Default Re: Folders inside the plugin folder
Pro Tools does NOT care about subfolders in the plugin folder. I keep all of my plugins organized in this way. The only thing to watch out for is when you update/install a new plugin to put it in the right folder and overwrite the previous one (otherwise you can wind up running two copies of the same plugin and Pro Tools does NOT like that!)
Matts Matts is offline
It has worked very well for me, I’ve been doing this for many years.
-matts
Old 07-14-2022, 12:43 PM
I forgot to mention this!
Old 07-14-2022, 12:49 PM
Thanks guys. Yes I see you'd have to take care when using installers/uninstallers and updating and such.
Just one more thing; If I reorganized and put some plugins in folders, and they would have new locations, would I have to delete 'InstalledAAXPlugIns' to make PT load all plugins again?
Old 07-14-2022, 01:28 PM
BScout BScout is offline
No. It auto rescans when the folder changes. No need to delete anything.
We use subfolders for mixers. So any mixer walks onto a Pro Tools system and drags their folder into the plugin folder. When done, it gets dragged back out. Folder named after each person.
(All the plugin installs are first done as if everyone has the license before being dragged out so all the ancillary files are already on the system)
Old 07-14-2022, 01:45 PM
Thanks, BScout. Good advice as always.
I now feel less nervous about experimenting a bit with this.
BTW, I've used labels (mac labels) to help organize plugin folder for some time. Basic Avid PT plugins - red, Avid extra plugins - orange, iLok licensed - yellow, and so on. Makes it easy to see newly installed and demos f.ex, because it would have no label. Works good to see things at a glance.
Old 07-14-2022, 03:08 PM
Eric Lambert's Avatar
Plugin updates getting confused about file paths is the reason I stopped altering the plugin folder, but if you're diligent about resetting it prior to an update then it shouldn't be a problem.
Old 07-14-2022, 04:28 PM
I just install and then move the plugin afterwards. My plugin folder is:
Plugin-Ins
BScout
Each Manufacturer
Acon Digital
Nugen
Lexicon
Makes it easy to check versions and do updates (just show the version column in Finder and check a complete manufacturer's line up, download, install, drag the whole group of "new" plugins back into the manufacturer folder ("replace" when you get the pop-up)
Only plugins at the root level of the plugin folder are the Avid ones.
Old 07-14-2022, 04:50 PM
And that never creates an issue when an installer needs to validate the presence of a former version of that plugin?
Routing Folder Inside Routine Folder - Solo Issue John9281 Pro Tools 3 03-20-2022 10:43 PM
Show tracks inside folders with folder hidden snowplaysmusic Pro Tools 3 06-22-2021 03:58 PM
Folder Spill with Nested Folders originalscottyg Avid S1, S3, Dock and Control App 0 12-03-2020 08:46 AM
Plugin Folders: Common vs Protoolls folder (Obsolete?) vincepaul 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 03-10-2009 09:33 PM
How to organize Plug-Ins into folders inside PT peneslapepe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-18-2004 06:35 AM
