ProTools white noise only with MBox 2 Pro not MBox 1?
Hi there,
Read a lot of forum posts on this, but can't find the answer... Just bought the Mbox 2 Pro to upgrade from the Mbox Original because am also moving to Snow Leopard, but as soon as I plucked it in and opened a session on ProTools LE 8.0.1 am getting very nasty white noises. I have tried listening on the headphones instead of monitors but the noise is just as bad. Also the CPU seems to easily overload. I have also tried different USB cables...no success. Any tips? Running ProTools Le 8.0.1 on MacBook Pro 10.5.8 And yes, the MBox Original works fine, so assuming it can't be any of the cables/leads. Cheers! |
Re: ProTools white noise only with MBox 2 Pro not MBox 1?
Which port are you plugging it in to?
If you have two, left and right. Try the left if you haven't already. There has been issues with USB architecture in the past and the advice was to use the left port. YMMV depending on your model of mac of course.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D --- iCON Photography |
Cool, will try, cheers!
White Noise, distortion, pops, loud noise in Pro tools 9 and mbox mini | Bigpit | Windows | 1 | 09-09-2013 09:26 AM |
MBox 2 White Noise | jtalk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 01-05-2009 07:54 AM |
Mbox White noise :((((( | johan2006 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-16-2008 07:53 AM |
Mbox white noise | ant.s | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-24-2007 10:03 AM |
white noise when using mbox with other daw | djorig | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-11-2006 08:07 AM |
