Tech Support Please Help!!!
I am re-installing my system from OS up and I am having some trouble with the MOTU timepiece AV. When I first installed about 1 year ago Tech Support said something about installing the drivers for the USB and MOTU and newer tech U drive in a specific order.
G3 blue and white OS 9.1 MIDI Time Piece AV USB PT 5.0 Please help me TECH GODS!!! |
Re: Tech Support Please Help!!!
-The only way I have seen MOTU interfaces work properly with Pro Tools is when installing FreeMidi (1.4x) _AFTER_ installing OMS. Installing FreeMidi after OMS will then update the System Folder>OMS Folder with some MOTU specific files which may give you the functionality you need with your setup. Restart the computer and launch FreeMidi. It will say something like “FreeMidi has detected OMS...Do you want to use FreeMidi or OMS?” Click “Use OMS”. This puts FreeMidi into OMS compatibility mode. From this point on, FreeMidi will reman invisible to you and all configuring/editing of interfaces and devices is to be performed in OMS.
Brent |
Thanks,
You guys (and gals) are the best. |
New tech support tools - Tech Support Folder | DigiTechSupt | Technical Alerts | 0 | 08-07-2007 08:13 AM |
Tech Support | batchmister1 | Pro Tools M-Powered (Win) | 0 | 08-05-2006 11:47 AM |
Tech support: Where Are You? | stephentrask | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 05-24-2005 07:20 PM |
I am tech support man for the day.... | silence_of_stone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 163 | 04-22-2004 12:36 PM |
HELP TECH SUPPORT | stuckinrap | ProControl, Control|24, Command|8 | 3 | 07-05-2003 02:34 AM |
