Old 12-15-2007, 03:33 PM
obsuleet obsuleet is offline
Default 1.6 ghz is that too slow for pt and plugins.
I want to get this dell laptop with 2 gigs of ram, xp and the processor is 1.6 is that too slow for pt and plugins.
Old 12-15-2007, 03:41 PM
sw rec sw rec is online now
Default Re: 1.6 ghz is that too slow for pt and plugins.
ABSOLUTELY
Old 12-15-2007, 03:57 PM
ggmmss ggmmss is offline
if you gotta have the dell then i would max out the ram
Old 12-15-2007, 04:05 PM
So will the maxed out ram compensate for the process speed?I don't have to have the dell but that's the only company that still has xp models, every other company has vista pre-installed on there pc's.
Old 12-15-2007, 04:30 PM
You will see a little more muscle with added ram but my best advice would be to get at or above the 2.0ghz processor point with as much ram as you can afford especially if you use soft synths and a lot of plugins.
Old 12-16-2007, 12:53 AM
3JDamon 3JDamon is offline
A 1.6GHz PC will not benefit from more ram. 2GB is already overkill for anything except a 3GHz+ dual core or a quad.
1.6 GHz is manageable, depending on your needs. You'll have to describe for us what you hope to do and what plugs you use. For example, if you're using convolution reverbs, you'll be able to use one and no other reverbs. There are several tricks to using delays to thicken reverbs and accomplish much of what several reverbs do, and delay is one of the least CPU-hungry plugs possible.
But if you're talking linear phase EQ's and transient manipulation etc, 1.6GHz won't cut it. 1.6 dual maybe.
And I hope you're talking Pentium M, a 1.6GHz Pentium 4 isn't going to do squat, and I don't recall the AMD laptop chips being much good at that speed either.
Old 12-16-2007, 07:13 AM
So basically i should just get a 2.0 ghz. pc with a intel core duo and 2 gigs of ram will be fine right? I plan using pt to track my beats from my fantom and once i track them i want to to be able to add different effects as well as soft synths.
Old 12-16-2007, 07:46 AM
What about this laptop?
http://www.newegg.com/Product/Produc...2E16834147354R
Old 12-16-2007, 11:58 AM
Violet Violet is offline
No that is a pentium M processor you 'need' core 2 duo at least. It will run slow even if all you are doing is what you say you'll be doing. But not after to long you will want to play with compressors, eq, and other fun plug ins.
2 gigs of ram min 667MHz or above
2.0 + core 2 duo(standard now a days)
I run a 2.66 and it starts being slow at when I have about 15 plugins average fyi
Most experienced pt users are using macs fyi thats not a invitation to a debate all of you Windows lovers, thats just how it is. Facts are facts.
PT 9.0.3
Windows 7 64 bit, 2x i7 PCs, 24GB, 3 SSD's, 5 HD's
....and a couple other toys.
Old 12-16-2007, 01:08 PM
Kirby B. Kirby B. is offline
Yeah, Mac laptop is is the accepted way to go even here in the Windows side. But it may be a budget consideration, which I understand. I agree that
You could dual boot, not a bad idea to have XP!
Digi002R PT2018 Win 10
INTEL Core i7 930, 3.52 Ghz
GIGABYTE GA-X58A-UD3R
CORSAIR XMS3 12GB 1600Mhz
2 X WD 1TB Caviar Black 64 GB cache
MOTU Traveller PT2018
MacBook Pro Mojave
16GB DDR3
Plugins slow to load wyman Pro Tools HDX & HD Native Systems (Mac) 5 02-03-2014 01:43 PM
instantiating plugins very slow CarNut 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-07-2009 05:21 PM
Pro Tools 7.4.2 Slow to Load Plugins KMFDM Pro Tools TDM Systems (Mac) 0 01-26-2009 07:06 AM
LOTS OF GREAT PLUGINS,BUT CPU IS TO SLOW? THE CUZIN 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-02-2004 08:51 AM
Slow Plugins Alejandro R Pro Tools TDM Systems (Mac) 1 08-21-2003 09:56 PM
