Keyboard Shortcut Comments in the Edit Window?
Hello
Is there a keyboard shortcut to open/close the comments section while in the edit window on Mac? I can't seem to find one... Thanks, Sparky
Pro Tools 2023.12.0 Avid Carbon Ventura 13.4.1 |
Re: Keyboard Shortcut Comments in the Edit Window?
No. You just have to assign your own key command.
(You can always check the Keyboard Shortcuts window to find out these answers. "Edit Window: Show Comments View" does not have a key combination assigned)
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Next project in this journey - learn to create/assign key commands Thanks BScout Sparky
Assigning your own it is pretty easy. Just open it up and explore it for 5 minutes. IT will even show you conflicts.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card. OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW. Almost every plugin |
There is a version of Soundflow that comes with my version of Pro Tools.
I have just started to look into this tonight thinking it might make some of the more common key command shortcuts I have started to use - easier to find… Also discovered there is an external keypad - Stream Deck - which looks like a time saver… Thoughts? Sparky
First use actual keyboard shortcuts as assigned in the Keyboard Shortcuts window.
Then you can assign those shortcuts elsewhere if you want to: SoundFlow, mouse buttons, StreamDeck. But start with the first thing of using Pro Tools keyboard shortcuts window. Reserve Soundflow for complicated workflows (like multiple steps) not silly things like show/hide a view. I've got, for instance, a custom keyboard command for "Show Name in Clips" so I can get that out of the way. And then my mouse has buttons assigned to "show name in clips", "show clip gain", "show clip gain line", cycle through modes, suspend/enable groups. I know all the keyboard commands by heart but I toggle these so often it comes in handy to just have them on my mouse. I then have two StreamDecks but these are for multi-step or SoundFlow specific commands. Things like a multi track export process or hide all empty tracks and set the window configuration. Things that take multiple keyboard commands (or mouse movements.) Think of the keyboard shortcuts window as creating building blocks and then StreamDeck/SoundFlow as assembling things with those blocks.
I use Keyboard Maestro. Its not expensive either. 36 bucks gets you a license. Keyboard Maestro takes sometime to get into and understand, but once you get into it, its VERY powerful. There are plugins that work with Streamdeck. Get KMlink over the Keyboard Maestro one as you don't have to deal with tricking it to see the same key as a different key. It just looks for the KM macros, Bob's your Uncle. Streamdeck configuring super simple. Folders, custom Icons (pretty much any size), simple to re-arrange and copy as well. I have like 4 solo clears in everyone of my different folders or root directory. It follows applications as well. This is just my most used Apps that I open often. Check it out
1. Window Configuration
2. Memory Location > Window Configuration |
Not sure what this means? I have windows configs to pull up a screen full of plugins.
Can't see changes while editing Comments in Edit window on Windows OS [PT-228098] | Skwaidu | Pro Tools | 26 | 09-11-2023 09:50 AM |
Comments in Edit Window Not Working in 12.7 | DAWgEAR | Pro Tools 12 | 7 | 01-24-2017 01:50 PM |
Trying to make keyboard shortcut for insert/sends F-J works for edit window only! | crizdee | Pro Tools TDM Systems (Mac) | 4 | 01-30-2009 04:30 PM |
toggle mix and edit window shortcut | daven | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-02-2005 02:02 PM |
Mix to Edit window shortcut | Cliffy_Boy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-29-2003 08:45 PM |
