Re: Keyboard Shortcut Comments in the Edit Window?
Make a Window Config of the Edit Window that:
1. Shows Comments 2. Hides Comments Mine are called "Edit Main" & "Edit Wide", triggered from 2 Memory Locations (which you can easily type a numeric keypad number to recall) |
Okay I see what you are referring to now. Thats a good solution. Now that windows configs works.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card. OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW. Almost every plugin |
Thanks for the "heads up" on the limitations of the free version of Soundflow... Sparky
Pro Tools 2023.12.0 Avid Carbon Ventura 13.4.1 |
Good and fair points... Thanks, Sparky
Here's the solution that seems to work for me. Created a window configuration with the comments column open and called it "Comments" Then in my memory locations window - I created a location called "Mix Comments" - and selected the "Comments" window configuration option and "Time Properties" set to "None" I already had a Mix setting in the memory locations window. Had to create a window configuration with comments section closed - so just called it "Mix" and add it to original Mix memory location - and now I can alternate between the 2 quite easily... Thanks for the inspiration Tweakhead Sparky
Be careful using it this way. I think, if you have any plug-in windows open at the time you recall this window config, it’s going to close all of those plug-in windows. Where as creating the key command for show comments will not. It will simply show the comments and keep whatever windows you currently have open.
Thanks, Sparky
The other thing is I read that I could import these settings into other session using the import session data and selecting window configurations only.
Tried it just now and this works as well! Nice... Sparky
Can't see changes while editing Comments in Edit window on Windows OS [PT-228098] | Skwaidu | Pro Tools | 26 | 09-11-2023 09:50 AM |
Comments in Edit Window Not Working in 12.7 | DAWgEAR | Pro Tools 12 | 7 | 01-24-2017 01:50 PM |
Trying to make keyboard shortcut for insert/sends F-J works for edit window only! | crizdee | Pro Tools TDM Systems (Mac) | 4 | 01-30-2009 04:30 PM |
toggle mix and edit window shortcut | daven | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-02-2005 02:02 PM |
Mix to Edit window shortcut | Cliffy_Boy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 09-29-2003 08:45 PM |
