Old 03-30-2020, 12:36 PM
supercharge supercharge is offline
Default Re: S1 modifier keys not set up
Originally Posted by EddieJones View Post
I think this may be because you are not using PT? these system Modifiers have to be supported by the DAW
They worked fine on my S3 though! The fact that I have 2 brand new S1's purchased at the same time and they both don't have these programmed is weird.
Windows 10 64bit i7 | 64gb ram | Cubase 10 pro
Old 03-31-2020, 12:55 PM
EddieJones's Avatar
I found out why the S3 is different, it uses Key Injection(similar to keyboard commands) to insert the Modifier commands, whereas all other EUCON surfaces uses EUCON. The benefit of EUCON is that the App doesnt need to be focused, the downside is that the DAW needs to implement it and it appears that not all have. I have asked software if we can make it an option to send Key Injection so that all DAW's can support this.
Old 03-31-2020, 01:59 PM
Thank you so much for your further advice.
So it is not something wrong with my machines then, just that it doesn't do it for Cubase.
Fingers crossed Software will be able to implement this. I'll keep my eye out for Eucon 21 then
Cheers
Hold Modifier keys? DBboy Avid S1, S3, Dock and Control App 7 10-27-2020 07:37 AM
S6 modifier keys not functional after 2.0.1 update sauna-l Avid S4/S6 2 10-09-2015 12:15 AM
C|24 Modifier Keys in 8.0.3 paulmellors ICON & C|24 1 02-10-2010 08:46 AM
Control 24 modifier keys broken in 8.0.3 crizdee Pro Tools TDM Systems (Mac) 12 02-06-2010 08:47 AM
Modifier keys...anyone remember Workman Pro Tools TDM Systems (Mac) 7 10-24-2005 03:08 AM
