Old 12-29-2011, 04:26 PM
Traveller Traveller is offline
Default PQ Cables and snakes????
Does anyone know if it would be possible to run PQ signal through a standard multi pair snake? Perhaps using pins 2 and 3 of two xlr connectors to supply the signal for one PQ? Trying to simplify my cable runs for 2012. Being able to run a 14 pair with a PQ built in would be awesome.
Thanks!
Old 12-29-2011, 10:06 PM
Tragic Dog Tragic Dog is offline
Default Re: PQ Cables and snakes????
I'm not knowledge enough to be able to comment on if that's possible, but Gepco sells some nice cable that has Ethernet and such as well as pairs for audio sends.
http://www.gepco.com/
They can even do custom cable with what you need/want in it.
Jon Lillie
Behind the Light Productions
PT 10-CPTK-Motu Traveler v1
Mac Pro 2x2.8GHz Quad-Core, 14gigs of ram
Macbook Pro w/Retina Display, 2.3Ghz i7, 16gigs of ram
Old 12-30-2011, 04:48 PM
Jeff W. Jeff W. is offline
Keep it under 75', and you should be fine, even if it's analog.
Old 01-11-2012, 08:35 AM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
This should be possible, given the right type of cable. A standard 3-conductor+shield mic cable won't work, as PQ controllers use a 4 pin wiring scheme for data and power. The cable included with each unit is starquad microphone cable, wired as follows:
Pins connect one-for-one at each end, with
- pin 2 & 3 wires twisted together
- pin 1 & 4 wires twisted together
- shield connected (in addition to the twisted pair wire) to pin 1 at both ends
So if you can run a starquad snake it should work out to the rated 100 foot max. The only unknown is if there would be any crosstalk/noise from running the data lines within the same snake as mic level signals. Seems unlikely that this would happen if a quality, shielded cable is used, but is something be aware of and check for.
Sheldon
***Lynx Aurora 8 w/Adat Card, Dsub XLR cables & Optical cables*** RuffJazzRecords Buy & Sell 2 08-17-2013 05:26 PM
Any issues running Digilink cable in conduit with audio cables vs power cables? ragbor Pro Tools TDM Systems (Mac) 2 09-07-2009 10:44 AM
snakes chrisk23 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 07-15-2005 07:47 PM
Help..Mbox..Unbalanced cables or balanced cables.. DRAFT 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 05-08-2005 07:07 PM
Snakes! Help! Bermaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 09-27-2004 07:09 AM
