Pro tools 8 "unable to locate digidesign hardware''!
Hi.I have just upgraded to pro tools 8,but have not been able to use it yet because every time i try to launch it,it cannot locate any hardware.I am usng an mbox 2 and it was working fine with pro tools 7.4..has anyone got the same problem or have any idea's,thanks.
Re: Pro tools 8 "unable to locate digidesign hardware''!
Are you using the older Macbook (pre intel). If so use the lefthand USB port only, not the right. I also found than the USB power takes a while to 'flow' into the mbox and get it recognised by the laptop.
Plug the mbox2 into the lefthand USB wait a couple of mins (until the LED's on the mbox2 reach full brightness) and then try to open protools. It is not a problem with the mbox (if it is Powerbook you have) but a problem with the macs internal architecture. A:)
I Love Audio!!! Last edited by 1ace1; 01-21-2009 at 09:29 AM. Reason: dyslexia |
Thanks for the suggestion.It is the intel macbook pro.I tried using the left usb port and waiting a few minutes for the LED's to fully light up but pro tools still doesn't recognise it.In system preferences it says the mac is connected to the mbox2..
I had the same problem this morning with my MBP. I re-installed the core audio driver, and it is now it seems to be working properly. Now I'm in the process of a clean re-install of PT8 on my Macpro. I don't know why but it seems that the PT drivers are all of a sudden conflicting with my audio-midi set up. I've been fighting with it all night!
Music is the Message |
BTW, I don't know if it's different for Mbox2 mini, but I've never had the left/right usb issue. It worked fine on any port(until PT8)
If it says Firmware Version <Not Available>, click "Show All" then click "Sound". Check under "sound effects", "output" and "input"... Does it see your Mbox 2 as an Mbox 2 or something else like Mbox 2 Academic or otherwise? If it shows up there as a regular Mbox 2, there is a Firmware Updater you can download to try and reload the firmware.. http://www.digidesign.com/index.cfm?...4&itemid=24364
If you don't have it backed up, do you really have it? [ Mac Pro 4x2.66 | 3x23" | 5GB | 4x500GB int. - 4x500GB ext. | 10.5.5 | PT8 003R | Command|8 | BM-5A's ] [ Macbook Pro 2.16 | 17" | 2GB | 1x120GB int. - 2x250GB ext. | 10.5.5/XPproSP2 | PT8 Mbox2Micro ] |
Hey,in system preferences it says that firmware version is <not available>,and in sound it comes up as mbox 2 academic.I downloaded the firmware updater but when i try begin it,it says "found no mbox2 connected"
Hi everyone,
I am having the same problem. I have used both an Mbox 2 and an Mbox 2 Micro along with v7.4.2, but upon the first launch of PT8, I get the message telling me "unable to locate digidesign hardware". There is no light or sign of life neither in the Micro nor the Mbox2. In System Preferences on the Mac, preference pane Mbox 2, it says that there is no hardware detected. How do I reinstall the Core Audio drivers, if that was a possible solution? |
Well, anyone?
My setup is the following: MBP 2.2 GHz Core 2 Duo, 2 GB RAM Mbox 2 and Mbox 2 Micro (not at the same time :) Maxtor OneTouch III 500 GB external HD (Firewire, used for recording and playback) Mac OS X 10.5.6 |
After a stupid amount of work, calls and research, here's the deal;
Digidesign "accidentally" flashed a bunch of MBox 2 units with the Academic Firmware. This firmware causes all of the problems we have all been experienced and have been described in this thread. This firmware does NOT work on Pro Tools LE above 7.4.2 on Mac OS X. Your unit has to be flashed with a new firmware or your unit has to be replaced. There are no other options, aside from running Pro Tools 7.4.2 With 45+ minute hold times and 3-4 week turnarounds for replacement units, it'd be nice if we could flash our own unit with the non-academic firmware... since this is Digidesign's screw up and not ours. BTW - I have a small note with "Important Notice regarding MBox 2 Firmware" from Digidesign about this accidental flashing of firmware with academic versions. What it doesn't say is "you can't run Pro Tools 8 with this MBox 2."
John Flowers | twitter.com/LifeZero | www.unscale.com Mac Pro running OS X 10.5.6 & MacBook Pro 10.5.6 Pro Tools LE 8.0 + Digi 003 Control + MBox 2 + MBox 2 Micro |
"Unable to locate digidesign hardware..." using HD Pro Tools 6.4.1 | poohdap | Pro Tools TDM Systems (Mac) | 5 | 06-24-2017 06:46 AM |
Brand new Mbox, Brand new pro tools LE 7.4. "unable to locate digidesign hardware" | eltore23 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-03-2012 10:13 AM |
"unable to locate digidesign hardware" message on pro tools 9 | echalk | Windows | 9 | 08-29-2011 03:37 PM |
003 + PT 8LE "Unable to Locate Digidesign Hardware!!!! | Shazamm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-30-2010 07:08 PM |
003 + PT 8LE "Unable to Locate Digidesign Hardware!!!! | Shazamm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-27-2010 06:56 AM |
