kvm extenders
Does anyone know of a high quality Keyboard mouse and VGA extender system that works well with the G4 USB??? (I'm looking for a solution less expensive than another networked CPU that works up to 250' or more)
Thanks |
Re: kvm extenders
At a 250 foot distance you'll need a device like the Gefen.com Cat5 extenders. You'll find they're not inexpensive..
John Caldwell
Pro Tools 2018.4 HDX, 192 and Lucid I/O 5,1 MacPro 12 Core; OSX 10.12.6 |
Re: kvm extenders
I've got an ADB 100 that extends the keyboard and mouse (but not the monitor) from the CPU,
but it's not USB. Maybe you could get a serial card... let me know if you're interested, I'll charge you a lot less than the factory. [email protected] |
Re: kvm extenders
Thanks, I'll check out the Gefen, and maybe look around for some other alternatives as well.
Re: kvm extenders
If you don't mind using an older keyboard and mouse, you could just get an ADB to USB adapter and put some 4pin DIN ends on a 250' piece of CAT-5. For the monitor, use high-quality RGBHV 75ohm coax and you can run very long distances with minimal loss. The only problem is that the monitor cable won't be cheap, but it'd still be less than a Gefen. I've built my own cables for this purpose with great results in the past. In terms of ease of use and minimal wiring time, the Gefen CAT-5 boxes are the way to go though.
-Evan |
Re: kvm extenders
I use the Gefen CAT5*3000R. It works great!
I went to there factory and was able to pick it up for $995.00. My control room is quite once again. |
Re: kvm extenders
You might try NTI at www.networktechinc.com - they make extension cables and KVM boxes for all platforms, and are very reasonably priced. I'm using their 50' VGA cable on a G4 (no booster) and it's perfect.
Warmest Regards, Brian |
Re: kvm extenders
Someone turned me on to NTI as well, but I can't figure out what to do about USB. There's no going back to ADB for me. How long can it go? do you need a repeater cable?
Re: kvm extenders
I'm not sure about length restrictions for USB drives, but a couple places around here are running 30' - 40' USBs for their Keyboard/mouse with no trouble.
The NTI sales guy said their USB extensions have a built-in repeater, so you can daisy-chain 'em and go waaaayy past spec length. Please post in this thread if you contact them & find out something more specific. (I'm still running 50' ADB w/iMate adapter to G4; haven't gotten used to new mini-keyboards yet.) Warmest Regards, Brian |
Re: kvm extenders
In this context, does anyone know when USB 2.0 will be useful for Midi and stuff? the gefen USB extender only does USB 1.0 or 1.1 and as many people appear to have problems with USB for Midi....well any info is appreciated. Sorry if this is a litttle OT in the thread. regards Janne A. |
DVI extenders. | Marsdy | General Discussion | 5 | 09-19-2011 06:16 AM |
How to Hook up MCU and 2 Extenders? | ReverbMerv | ProControl, Control|24, Command|8 | 2 | 12-23-2006 09:45 PM |
Mackie MCU and Two Extenders? | ShakaBrah | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-10-2005 11:32 AM |
Anyone using Original HUI and MC Extenders? | brinaddison | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-05-2004 07:29 PM |
HD2, 02R96 & USB Extenders | ThreeBlake | Pro Tools TDM Systems (Mac) | 2 | 05-15-2003 04:26 PM |
