Old 03-08-2005, 09:36 PM
Bloux Bloux is offline
Default Hyperthreading Question
I understand its not supported. however, I upgraded from W98 and AMD t-bird 1.3 to a 3.3ghz Xeon running PTLE 5.3.. hyperthreading is enabled in bios yet everything "seems" to be working properly. I do get a random DAE increase Buffer Size error even when I'm not using a large amount of plugs. (seems intermittent)..
if hyperthreading is not supported, yet working on my system, How will a HT problem manifest itself? In other words, what negative effects will I encounter by having hyperthreading enabled on my system?
Old 03-09-2005, 02:45 AM
neeel neeel is offline
Default Re: Hyperthreading Question
I experience no issues with HT enabled. In fact when I disable it i experience a significant performance decrease.
If it aint broke.....
neeel
MBOX MINI PTLE 8.0.3
MAC OSX Snow Leopard
Mac Mini 1.5Ghz Intel
2 Gig RAM
Old 03-09-2005, 03:51 AM
well I disabled hyperthreading and saw an improvement on the DaveC test. I went from 32-5 to 32-13. I'll see how that transferes to the real world, but at 128 sample rate it did noticeably do much better.
thanks to Phil O'keefe, he linked me up to the digi answerbase where they definetly reccomend disabling HyperThreading as it will effect plug in, track count, and overall computer efficeincy. so far they're right on!
thanks.
Old 03-09-2005, 07:56 PM
bb_aus bb_aus is offline
with these questions you need to state what mobo/chipset you are using
HT is working fine for many with an Intel 865PERL mobo, however can cause nothing but problems with other boards
3Ghz P4 Northwood
Intel 865PERLL
Hyperthreading: Ok for PT 7 now? Scott Cairns 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-18-2007 06:10 AM
QUESTION: Hyperthreading for PT 7 - MBox 1? inca 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-04-2006 08:00 AM
...hyperthreading.. jrod096 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 11-28-2005 11:19 AM
HyperThreading? Matt Reisinger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-10-2004 08:19 PM
HyperThreading yes or no? ricren 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 02-21-2003 06:20 PM
