Re: can hardly hear myself while recording
That is one of the reasons I keep asking for a clear description of how exactly monitoring is begin done/suggesting a test of pure Pro Tools based monitoring.
do you mean direct through the interface as in headphones plugged in to Mbox?
Macbook Pro Mac OS 10.10.3 Mbox 2, Pro Tools 11 |
There are two ways sound gets from your microphone(s) to your headphone (or monitors). One is though Pro Tools (aka software monitoring). The other is though dedicated motioning hardware in your Mbox). The blend of those two is what the mix knob controls. We cannot even follow whether you are trying to use software or hardware motioning, if you understand the difference, etc. You might for example be using a blend of mostly hardware monitoring but wasting your time in Pro Tools trying to get stuff louder and it won't go louder because you are mostly hearing the hardware motioning path. Maybe you understand all this and are well beyond it in debugging--but we have no way of knowing that. See why we need a *clear* description of exactly what you are doing. |
So both mic you have been experimenting with are the same model? And both behave the same? I thought you said before that only one of you mics had this problem. Can you just start over and in one post clearly describe what is going on. include photos, drawings, and details -- whatever you need to do to make this clear to somebody not looking over your shoulder. Incldue details like what mic models, inputs, knob positions, you are talking about. You've been asking about problems kind of like this for over a year now right? You may have some misunderstanding about something, and/or a faulty piece of hardware, either way it would be good to get to the bottom of this. |
#16
When I had meant the other mic was working fine I was referring to it being hitched up to a mixing board. ANYWAY (Starting over) I have the Mix Knob turned all the way clockwise like you are suggesting. I have an input level on the mono audio track reading -6 (should be loud enough for headphones) I have no plug ins on this track. When I hit record and Solo the record track I don't hear myself in the headphones except for a faint sound of myself. The tracks fader is turned all the way and the input level on the Mbox 2 is all the way up. (so it's input level signal is clipping, I obviously wouldn't record with it clipping I just turned it up this far to see if increasing the input made it louder in the headphones.) The other strange thing is I don't even get an input signal of green unless the input knob on my Mbox 2 is turned up about 70 percent all the way up. I can record just fine as when I play it back it's loud and it's playback level is in the yellow.
#17
So this behavior follows the mic, if you take the other mic and connect it you can now hear more loudly while tracking? Oh and I forgot you are actually using an MBox 2 not an MBox 2 Pro so the low latency monitoring issue in Pro Tools 11 won't affect you here... since there is no Pro Tools low latency monitoring with a plain MBox 2. Again, it almost sounds like you might be in the wrong track monitoring mode, but we don't know if you are tryign to punch in, use quick punch etc. etc. So make sure you are not in punch in or quick punch mode, make sure you have the track record armed and the transport in record mode (not quick punch) and press play. Can you now hear the mic input? If not try from a new empty session with just one track and one master fader and post screenshots of the mix window and transport window with this occurring where we can see the meters and tracks and read any text clearly. |
#18
Don't ask me why it says input 7. I have never been able to figure out why it says that with an Mbox 2.
#19
You can name the inputs to whatever you want them to be. Input 7 could be input 1 on the device.
#20
yeah I know but I don't recall renaming 1 to 7 LOL
Can't hear track I'm recording on but can hear all others | Durstlaw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 12-14-2022 01:24 PM |
How to hear the metronome during recording? | jackroylee | macOS | 3 | 05-29-2012 03:56 PM |
8.0 cs3--Dont hear take while recording... | scottleader | Pro Tools TDM Systems (Mac) | 10 | 10-14-2009 03:28 PM |
Can't hear vocals during recording | mikecamp1978 | Pro Tools M-Powered (Mac) | 5 | 04-25-2009 01:45 PM |
How Can I Hear The Vocalist Without Recording | Craiger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-04-2009 09:16 PM |
