#21
Re: How do you pros compensate delay
I'm pretty sure that as long as the "delay" sample count on each track is under the amount of your buffer.. you shouldn't hear any latency.. I use SSL Channel on each channel of my mixes and it ass 1 sample of latency. and most of my other plugins per channel have 0. Thats what i use for tracking at 64 buff
and once im going to mix down if i put buffer up to 1024 then on Master channel goes; Digi 7 ban(for low end cut at 20hz) 0 latency, then SSL Comp 1 sample latency, then Maxim 1024 Latency... but its on the master so it doesn't put the mixed channels out of sync. and if im not mistaken.. if you have your buffer at 1024 on mix down and your tracks have plugins with 0-1024 sample latency.. they will be buffed.. and there for in sync. Plugins like Waves C-1 and some of that other crap that adds liek 3600 sample latency in my opinion shouldn't REALLY be used as an RTAS it should just be an AS... but the company wants you to have more options which in turn presents more problems with latency. correct me if im wrong please because this is what i think is correct.
-AIM: RS Recordings -Skype: RSRecords | Pro Tools 8 Native | Windows 7 64-bit| Q6600 @ 3.0ghz | 8GBs RAM | Digi002r | Studio Site: Red Sneaker Records |
#22
https://www.thirdeyerecording.com/ |
#23
A Digi rep told me otherwise at the S-S-R in manchester but he told me wrong as i started a thread up about this last year and it was confirmed it's for the above, unfortunately....
PTLE8 with an Mbox 2, for now!
#24
Does anyone here TRACK WITH SSL's on? I thought at 64 this might work, but i havent tried it so i havent checked it out.
We don't have the user centricity. Until we understand context, which is way beyond presence — presence is the most trivial notion, just am I on this device or not; it doesn't say am I meeting with something, am I focused on writing something. [LIST][*]Bill Gates .NET Briefing Day Speech (24 July 2002) |
#25
Not true.
#26
1. There's ABSOLUTELY NO CONNECTION between buffer size and plugin latency , unless we're talking about DSP-card-based plugins like UAD or Powercore.
2. If you track with your SSL channels activated, add 1 sample of delay to the already 64 samples of your buffer size. So you have 65. Doesn't sound that much worse than 64... So you can leave it on. |
#27
Hmm.. alright.. well i guess its a good thing i don't use plugins that have high(or any) latency.
#28
care to drift back to 2006??? discussion been goin' on for quite some time
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#29
Yeah but then you're stuck using Logic.
Unable to compensate delay | supersonic1000 | macOS | 2 | 10-01-2011 01:38 PM |
Delay from Inserts, How to compensate | CisumBlue | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 01-24-2010 08:47 AM |
Compensate for Delay question | Raggi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 10-30-2007 06:13 AM |
compensate delay of UAD-1 plugins on aux-bus? | fizzler | Pro Tools M-Powered (Mac) | 1 | 09-23-2006 01:23 PM |
How to compensate for midi delay | surchur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-02-2001 10:16 AM |
