cpu overload -- ram?
Hi, I just set up ProTools 8 m-box mini on a new imac 20" 2.66 ghz. Getting the CPU overload on just a few tracks with Structure/Xpand and browsing loops in the workspace browser. Using only digi installed plugs, configured everything as per recommended. External F/W 400 drive --> imac 800 port via 400/800 cable, though error is happening on just midi sessions with or without a few audio loops. [edit: now getting the cpu -6101 error with one instance of structure/3 parts. Static as well b4 the error message. Buffer size 1024. Wondering if I should be calling tech support at this point...?]
So, looking at the Pro Tools System Usage, my RTAS CPU is under 5%. I configured playback engine to increase H/W buffer size and limited RTAS cpu to one processor at 65%. Then I looked at the RAM usage with Apple activity monitor and it's practically maxed out: used aprox 1.5 GB, Free: 200-300MB. I have 2 gigs that came with the iMac... Is this a ram issue? BTW, does anyone have suggestions on which RAM to buy and where? I've heard that OS X and PT can be particular as to which kind but I'd like to save $ if possible... Thanks!!! |
Re: cpu overload -- ram?
I am so bummed right now. A new iMac, mbox mini and I'm getting CPU overload messages all the time with very small sessions. I'm wondering now if this is really a ram issue or not, I should be able to run at least 1 virtual instrument in Pro Tools without this error?
Let's see, other pertinent info: OS X version 10.5.6 iMac 2.66 Ghz intel core 2 duo, 2GB stock ram Pro Tools V 8.0, Mbox Mini Motif Rack via usb Korg Microkontrol usb Kensington Expert Mouse Maxtor 500Gb f/w 400 HD only Pro Tools 8 installed plug-ins |
Well, one thing I missed was that I had used the mbox mini for the system output recently. Changing that back to the imac default speakers has improved things, will try a new sesh with lot's of plug-ins/instruments and see what happens...
[edit] Made a new session with 5 rtas instruments: boom, structure, xpand(2) and piano. Performance is better but still getting cpu errors including a new one: -9128 "you are running out of cpu power. Remove some RTAS plug-ins or increase the CPU Usage Limit in the Playback Engine dialog". Playback settings are: buffer: 512mb, processor: 1 at 50%. PT activity monitor shows rtas cpu around 10-15%. Apple activity monitor shows 10-15mb free ram. So, I guess I'm back to my original question... do i need more than the stock 2 GB of ram that came with the iMac to stop the CPU error messages? anyone? Hello world? Last edited by WestphalMusic; 05-13-2009 at 11:26 PM. Reason: update from test session |
Try changing the Playback Engine settings to 1 processor at 85%.
And, yes, getting more RAM is very likely to improve performance, especially if you're using samplers that load samples into RAM. Just to be absolutely sure - you've definitely disabled Firewire networking on this machine, yes? |
Thank you. Firewire Networking has been disabled. I've tried changing the playback 1 processor to just about every setting from 50% to 99%, still get the cpu errors. They usually happen at playback start and then subside for a while. Before investing in Ram, I'd like to confirm that this is not an mbox hardware issue since I just purchased it. Do you think I need more than 2 GB of ram to run 4-5 VIs? If so, should I only purchase Apple Ram?
If you stream thing into the ram, than you definately need more than 2gb. No need to buy appleram.
Tamas Dragon
my blog:Tamas Dragon |
What are the rest of your system specs? |
Imac 20" (Leopard 10.5.6) Intel Core Duo 2,66 Ghz. 320Gb, 4Gb RAM. Pro Tools LE 8 (with cs2 update), Mbox2 by USB and external disk Lacie d2 Quadra by Firewire 800. |
Also, you may want to visit the General Troubleshooting thread, as it has several other suggestions that may help. |
CPU Overload | Jmissy87 | Pro Tools 10 | 4 | 05-13-2013 10:04 AM |
cpu overload | maxidud999 | macOS | 3 | 03-14-2013 06:48 PM |
CPU overload | aldoriba | Pro Tools M-Powered (Mac) | 1 | 12-09-2008 05:25 AM |
CPU overload | marcvise | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-06-2008 12:56 PM |
CPU overload | Raggi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-20-2005 02:49 PM |
