Old 06-06-2001, 06:21 PM
serguel serguel is offline
Default Mackie D8 Mixer + Mix plus
I can't get the any signal from mackie to PT.
I work via the Mackie Digital card to PT digital input to 888/24.Mackie doesn't send the sound. I've tried a couple times for different options.
any ideas&helps appreciate.
Thanks
Old 06-06-2001, 08:26 PM
Corey Shay Corey Shay is offline
Default Re: Mackie D8 Mixer + Mix plus
If I remember correctly each channel you assign out of the mackie's digital I/O cards needs to be assigned in the 1-24 routing matrix. Are you using AES cards? If so do you have your 888's channel pairs all set to digital?
Old 06-07-2001, 08:58 AM
Thanks for your respond.
I've to use AES card w/MAC.
I set up channel pairs to digital on 888's.
I'll try your advices.
Thanks
OT - Mackie 1202-VLZ 12 Mixer and PT LE superpenguin79 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 08-19-2004 01:37 PM
focusrite through a mackie mixer aziel General Discussion 12 10-14-2002 10:05 AM
Mackie mixer AdamF 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-06-2001 08:35 AM
brief mackie mixer query otto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-08-2001 02:46 AM
Mackie 1402vlz mixer? Mook 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 08-29-2000 08:44 PM
