system drive
should the pro tools LE program be installed to the system drive or to the dedicated audio drive? Which will give me the best results?
I currently have it on the system drive under program files and then store all my projects to the D drive which is dedicated just for audio. |
Re: system drive
Exactly what I have done, and I believe, it's exactly what you should do.
You want the audio path seperated as much as possible from anything else that is likely to compete with it. And PT is the most likely program to process at the same time as audio. I've got IDE drives, I presume the same applies for SCSI?
Rod |
No Audio, But Just Samples. System Drive Or Seperate Drive. | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 10-10-2010 03:47 PM |
System Drive and Audio Drive Question. | philip888 | Pro Tools M-Powered (Win) | 2 | 06-03-2009 11:30 PM |
Audio drive plus system drive, where Structure? | Blustar | Virtual Instruments | 3 | 09-17-2008 04:01 PM |
scsi ultra160 disk for system drive and audio drive | jazzle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 12-23-2001 06:54 AM |
anyone using the system drive and storage audio drive in the same SCSI chain? | riorecords | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-15-2000 11:09 PM |
