  #71
Old 03-24-2023, 04:04 PM
Eric Lambert's Avatar
Default Re: Pro Tools 2023.3 is out
Originally Posted by Blake Henderson View Post
If you're like me and have a large number of plugins you may need to remove half of them from the plugin folder and load PT. Once you get in, quit the app and restart after putting those plugins back into the plugin folder.
This has been an issue for years and happens to me every time I upgrade PT.
It was definitely a problem back when PT was a 32-bit app and it couldn't work with more than 4GB oF RAM (not enough to get all plugin into memory that first time), but since PT11(ish) it should be able to load everything in without issue. Unless you have overall RAM limitations. How much RAM do you have?
Regardless, your comment about loading 1/2 at a time is a solid workaround. I'm just saying that it *shouldn't* be necessary with as far as PT is concerned.
  #72
Old 03-24-2023, 04:09 PM
Blake Henderson Blake Henderson is offline
I fully agree that I *shouldn't have to but I'm assuring you that it's become a routine problem for me, probably for years now. I have 64GB of ram on an M1 Max so ram isn't the issue. I'm also someone who routinely updates all plugins so that I'm not using oldies.
Clumsy Congregation
  #73
Old 03-24-2023, 04:16 PM
Ben Jenssen's Avatar
Back on topic or start your own thread.
  #74
Old 03-24-2023, 05:32 PM
Well yes that's plenty of RAM and a modern computer. I'm not sure what's going on there but it definitely shouldn't be doing that. Have you contacted Avid support?
  #75
Old 03-24-2023, 05:34 PM
He's asking about issues with 2023.3 so it is on topic.
  #76
Old 03-24-2023, 06:36 PM
flommer flommer is offline
Hi - I have a new M2 Pro Mac Mini and I have waited until today to plug in my iLok and give PT a go because of this non-beta release for apple silicon.
Have not tried very much yet, but all 3 of the play/synth/groovecell plugs just open with an empty black window. I have them activated on my iLok so I don't think that's a problem... Not even sure what else to check. I installed basically everything via Avid link but I also tried the stand alone installers.. Any help is appreciated.. thx
***wow my profile is out of date - please ignore all of that lol***
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
  #77
Old 03-24-2023, 06:48 PM
noah330 noah330 is offline
Mac Studio with a PTN card in a chassis.
Installed the HD Driver, Installed ProTools update.
Everything worked great for me. I restarted and got an error message to increase buffer size/it may be a sync error.
Installed OS update (Ventura). Same error.
I restarted in safe mode (hold shift).
All is perfect.
I need to give Waves some money. Everything else (SoundToys, Eventide, SSL, NI, Sonnox, UA) works as expected.
Apple M1 Mac Studio (base model)
ProTools Carbon w/SSL XLogic MADI-AX
Instagram:
https://www.instagram.com/sparkletune/
  #78
Old 03-24-2023, 07:02 PM
Siegfried Meier Siegfried Meier is offline
Grid issues here when tempo is anything but 120 - grid numbers aren't whole numbers, I made a separate post. Anyone else seeing this?
  #79
Old 03-24-2023, 09:38 PM
Fishbone Fishbone is offline
Tested here with different tempo values and got no such error.
Grid works as expected, with whole numbers that escalates into subdivisions according with the zoom level
  #80
Old 03-25-2023, 03:12 AM
redmount redmount is offline
Originally Posted by redmount View Post
confusing me :
Apple Silicon known issues :
"Melodyne is Rosetta only, and will not install with Pro Tools if Rosetta is not already installed. Effects Air-Gapped systems only (PT-300227)"
Isn't Melodyne 5.2 native on Silicon Macs as stated on the Celemony website ?
What do I don't understand in the Apple Silicon / Rosetta concept ?
Thanks.
What’s due in 2023? noiseboyuk Pro Tools 57 07-06-2023 05:01 PM
Today's AIR FX and Instrument 2023.3 updates re-install 2023.2! off the wall Pro Tools 9 03-28-2023 10:33 AM
2023 Apple Silicon and Pro Tools Chevron Pro Tools 59 03-21-2023 07:54 AM
32 Channel - Apple Silicon - Pro Tools Rig in 2023 ? T-Low Pro Tools HDX & HD Native Systems (Mac) 25 01-02-2023 09:30 PM
