  #51
Old 10-24-2008, 07:14 AM
Teolin Teolin is offline
Default Re: Play/Pause issue driving me nuts...
Here is the info on the Sandra from Digi.
I tried getting the utility to spit out a version report, and it says it's done processing, but nothing appears. Where does the tech utility spit the report to?
Please - Use SiSoftware's Sandra Lite application to generate a full system profile:
www.sisoftware.co.uk
Under SiSoftware Sandra, click on "Download & Buy" to download the free Sandra Lite version or purchase other versions. After installing Sandra, click on the 'Hardware' tab and run the 'Computer Overview', then copy and paste into your post here on the DUC.
Pro Tools 12.4
HDN, PCIe, Omni & Digi 192
ASUS Sabertooth, Intel i7 3820 3.6Ghz
32 GB 1600Mhz Corsair RAM
SSD 500GB Samsung
WIN 10 64bit
  #52
Old 10-24-2008, 11:05 AM
DigiTechSupt's Avatar
I'm seeing a few plug-ins that are really questionable:
W32i DLL ENU 0.0.0.0 shp csr hall.dpm
- - - - - csr hall.dpm.rsr
W32i DLL ENU 0.0.0.0 shp csr inverse.dpm
- - - - - csr inverse.dpm.rsr
W32i DLL ENU 0.0.0.0 shp csr plate.dpm
- - - - - csr plate.dpm.rsr
W32i DLL ENU 0.0.0.0 shp csr room.dpm
- - - - - csr room.dpm.rsr
What are these and why do they not show version numbers?
Same goes for most of these - and the ones with version numbers are definitely outdated and should be updated:
W32i DLL ENU 1.0.0.1 shp tracks.dpm
- - - - - tracks.dpm.rsr
- - - - - tracks.ini
W32i DLL ENU 0.0.0.0 shp tracks1.x.dpm
- - - - - tracks1.x.dpm.rsr
W32i DLL ENU 0.0.0.0 shp tracks1.xclipper.dpm
- - - - - tracks1.xclipper.dpm.rsr
W32i DLL ENU 0.0.0.0 shp tracks1.xcompressor.dpm
- - - - - tracks1.xcompressor.dpm.rsr
W32i DLL ENU 1.3.0.0 shp tracks1.xequalizer.dpm
- - - - - tracks1.xequalizer.dpm.rsr
W32i DLL ENU 0.0.0.0 shp tracks1.xlimiter.dpm
- - - - - tracks1.xlimiter.dpm.rsr
W32i DLL ENU 1.0.0.1 shp tracksclipper.dpm
- - - - - tracksclipper.dpm.rsr
- - - - - tracksclipper.ini
W32i DLL ENU 1.0.0.1 shp trackscomp.dpm
- - - - - trackscomp.dpm.rsr
- - - - - trackscomp.ini
W32i DLL ENU 1.0.0.1 shp trackseq.dpm
- - - - - trackseq.dpm.rsr
- - - - - trackseq.ini
W32i DLL ENU 1.0.0.1 shp trackslimiter.dpm
- - - - - trackslimiter.dpm.rsr
- - - - - trackslimiter.ini
After removing or updating these, please trash preferences so that plug-in data can be re-cached.
Avid Audio Tech Support
Support FAQ
  #53
It should place it on your desktop. Are you not seeing it there?
Support FAQ
  #54
Old 10-24-2008, 03:51 PM
HeySchlitz HeySchlitz is offline
Those are all from the Total Effects Bundle from IK Multimedia. CSR reverbs, T-Racks, Amplitube and Ampeg SVX. I bought this after I reported the original issue...so I would doubt they are the cause...but I agree those versions look goofy. They are the most up to date from their website tho.
I can try moving them all out again and trashing the prefs with the Tech Support Tool. I'll also try to get a sandra report tonight (thanks for the link Teolin).
Edit to add: Thanks for taking the time to look through my list!
  #55
Old 10-24-2008, 05:50 PM
Here is version list from the utility.
Version List as of Fri 10/24/2008 18:48:14.42
Pro Tools Version
W32i APP ENU 7.4.0.326 shp protoolsle.exe
Plug-In Versions
c:\program files\common files\digidesign\dae\plug-ins\*.*
W32i DLL ENU 7.4.0.168 shp bf essential clip remover.dpm
- - - - - bf essential clip remover.dpm.rsr
W32i DLL ENU 7.4.0.168 shp bf essential correlation.dpm
- - - - - bf essential correlation.dpm.rsr
W32i DLL ENU 7.4.0.168 shp bf essential meter bridge.dpm
- - - - - bf essential meter bridge.dpm.rsr
W32i DLL ENU 7.4.0.168 shp bf essential noise meter.dpm
- - - - - bf essential noise meter.dpm.rsr
W32i DLL ENU 7.4.0.290 shp bf essential tuner.dpm
- - - - - bf essential tuner.dpm.rsr
W32i DLL ENU 7.4.0.168 shp bombfactory bf76.dpm
- - - - - bombfactory bf76.dpm.rsr
W32i DLL ENU 7.3.0.117 shp chorus.dpm
- - - - - chorus.dpm.rsr
W32i DLL ENU 7.3.0.117 shp click.dpm
- - - - - click.dpm.rsr
W32i DLL ENU 7.3.0.117 shp d-verb.dpm
- - - - - d-verb.dpm.rsr
W32i DLL ENU 7.4.0.309 shp digirewire.dpm
- - - - - digirewire.dpm.rsr
W32i DLL ENU 7.3.0.117 shp dither.dpm
- - - - - dither.dpm.rsr
W32i DLL ENU 7.4.0.315 shp dynamics iii.dpm
- - - - - dynamics iii.dpm.rsr
W32i DLL ENU 7.4.0.309 shp elastic audio.dpm
- - - - - elastic audio.dpm.rsr
W32i DLL ENU 7.3.0.117 shp eq iii.dpm
- - - - - eq iii.dpm.rsr
W32i - - - - ezplayer.dpm
- - - - - ezplayer.dpm.rsr
W32i DLL ENU 7.3.0.117 shp flanger.dpm
- - - - - flanger.dpm.rsr
W32i DLL ENU 7.4.0.168 shp funk logic mastererizer.dpm
- - - - - funk logic mastererizer.dpm.rsr
W32i DLL ENU 7.3.0.117 shp invert-duplicate.dpm
- - - - - invert-duplicate.dpm.rsr
W32i DLL ENU 1.0.0.0 shp ixl clip statistics.dpm
- - - - - ixl clip statistics.dpm.rsr
W32i DLL ENU 1.0.0.0 shp ixl level meter(h).dpm
- - - - - ixl level meter(h).dpm.rsr
W32i DLL ENU 1.0.0.0 shp ixl level meter.dpm
- - - - - ixl level meter.dpm.rsr
W32i DLL ENU 1.0.0.0 shp ixl multimeter.dpm
- - - - - ixl multimeter.dpm.rsr
W32i DLL ENU 1.0.0.0 shp ixl spectrum analyzer.dpm
- - - - - ixl spectrum analyzer.dpm.rsr
W32i DLL ENU 1.0.0.0 shp ixl stereo analyzer.dpm
- - - - - ixl stereo analyzer.dpm.rsr
W32i LIB ENU 1.0.0.375 shp izotope_radius_win32.dll
W32i DLL ENU 1.0.2.0 shp melodyne plugin.dpm
- - - - - melodyne plugin.dpm.rsr
W32i DLL - 3.2.2.0 shp melodynebridgertas.dpm
- - - - - melodynebridgertas.dpm.rsr
W32i DLL ENU 7.3.0.117 shp mod delay ii.dpm
- - - - - mod delay ii.dpm.rsr
W32i DLL ENU 7.10.3077.0 shp msvcp71.dll
W32i DLL ENU 7.10.3052.4 shp msvcr71.dll
W32i DLL ENU 7.3.0.117 shp multi-tap delay.dpm
- - - - - multi-tap delay.dpm.rsr
W32i DLL ENU 7.3.0.117 shp normalize-gain change.dpm
- - - - - normalize-gain change.dpm.rsr
W32i DLL ENU 7.3.0.117 shp ping-pong delay.dpm
- - - - - ping-pong delay.dpm.rsr
W32i DLL ENU 7.3.0.117 shp reverse-dc removal.dpm
- - - - - reverse-dc removal.dpm.rsr
W32i DLL ENU 7.3.0.117 shp signal generator.dpm
- - - - - signal generator.dpm.rsr
W32i DLL ENU 7.3.0.117 shp signaltools.dpm
- - - - - signaltools.dpm.rsr
W32i - - - - superior drummer.dpm
- - - - - superior drummer.dpm.rsr
W32i DLL ENU 7.3.0.117 shp time comp-exp-pitch shift.dpm
- - - - - time comp-exp-pitch shift.dpm.rsr
W32i DLL ENU 7.4.0.270 shp time shift.dpm
- - - - - time shift.dpm.rsr
W32i DLL ENU 7.3.0.117 shp timeadjuster.dpm
- - - - - timeadjuster.dpm.rsr
W32i DLL ENU 7.4.0.197 shp tl space native.dpm
- - - - - tl space native.dpm.rsr
W32i DLL ENU 7.3.0.117 shp trim.dpm
- - - - - trim.dpm.rsr
W32i DLL ENU 2.0.0.9 shp urs n12 series eq native.dpm
- - - - - urs n12 series eq native.dpm.rsr
W32i DLL - 1.0.1.984 shp xpand!.dpm
- - - - - xpand!.dpm.rsr
Plug-Ins (Unused) Versions
c:\program files\common files\digidesign\dae\plug-ins (unused)\*.*
W32i DLL ENU 7.3.0.117 shp dynamics ii.dpm
- - - - - dynamics ii.dpm.rsr
W32i DLL ENU 7.4.0.309 shp elastic audio.old
W32i DLL ENU 7.3.0.117 shp eq ii.dpm
- - - - - eq ii.dpm.rsr
- - - - - [plug-ins (unlicensed)]
W32i DLL - 1.0.0.0 shp structure.dpm
- - - - - structure.dpm.rsr
- - - - - [toolkits]
Music Production Toolkit is not installed.
DV Toolkit 2 is not installed.
Digitranslator is not installed.
DV Toolkit 1 is not installed.
Pro Tools 12.4
SSD 500GB Samsung
WIN 10 64bit
  #56
Old 10-25-2008, 06:24 AM
Kris75's Avatar
Kris75 Kris75 is offline
Space Cabin Audio
Well this issue had become a MAJOR PITA and embarrassment for me. Then I read that some NVIDIA drivers could be the cause. I needed dual VGA out anyways so I spent $50 on a new card. I have not had the issue in two days now(Fingers Crossed) and after my session tomorrow if it continues to stay away I will consider this issue a problem with my video card.
Here is to hoping.
NOTE: I had never had this problem until I moved my computer from one studio to the other. Perhaps the card was damaged on route.
Sign up for all things....AWESOME!
Kris
May the music move you
  #57
Old 10-25-2008, 11:28 AM
mano111 mano111 is offline
Here is to hoping.
What new card did you get?
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD
PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9
  #58
Old 10-25-2008, 04:53 PM
SiSoftware Sandra
System
Host Name : OPUS
User : xxxxx
Workgroup : WORKGROUP
Processor
Model : Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz
Speed : 2.83GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 1 Unit(s)
Type : Quad-Core
Internal Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 On-board Cache : 2x 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing
System
System : System manufacturer P5QC
Mainboard : ASUSTeK Computer INC. P5QC
Bus(es) : ISA PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
System BIOS : American Megatrends Inc. 0803
Total Memory : 3.25GB DIMM DDR3
Chipset
Model : ASUS Eaglelake DRAM Controller
Front Side Bus Speed : 4x 333MHz (1.33GHz)
Total Memory : 4GB DIMM DDR3
Memory Bus Speed : 2x 400MHz (800MHz)
Video System
Adapter : NVIDIA GeForce 8800 GTX (768MB DDR3, 533MHz/1.24GHz/2x900MHz, PCIe 1.00 x16, PS3.0, VS3.0)
Graphics Processor
Adapter : GeForce 8800 GTX (1.00, 768MB, 1.35GHz)
Storage Devices
ST3250410AS 250GB (SATA300, 3.5", NCQ, 16MB Cache) : 233GB (C:)
ST3750330AS 750GB (SATA300, 3.5", NCQ) : 699GB (F:)
ST3250410AS 250GB (SATA300, 3.5", NCQ, 16MB Cache) : 233GB (D:)
ST3750330AS 750GB (SATA300, 3.5", NCQ) : 699GB (E:)
SONY DVD RW DW-G120A (SCSI, DVD+-RW, CD-RW) : N/A (G:)
Logical Storage Devices
Opus (C:) : 233GB (NTFS) @ ST3250410AS 250GB (SATA300, 3.5", NCQ, 16MB Cache)
Samples (F:) : 699GB (NTFS) @ ST3750330AS 750GB (SATA300, 3.5", NCQ)
Games (D:) : 233GB (NTFS) @ ST3250410AS 250GB (SATA300, 3.5", NCQ, 16MB Cache)
Audio (E:) : 699GB (NTFS) @ ST3750330AS 750GB (SATA300, 3.5", NCQ)
CD-ROM/DVD (G:) : N/A @ SONY DVD RW DW-G120A (SCSI, DVD+-RW, CD-RW)
3.5" 1.44MB (A:) : N/A
Peripherals
LPC Hub Controller 1 : ASUS LPC Interface Controller
Audio Device : ASUS HD Audio Controller
Audio Codec : Realtek Semiconductor 888 High Definition Audio
Serial Port(s) : 1
Disk Controller : ASUS 4 port SATA IDE Controller
Disk Controller : ASUS 2 port SATA IDE Controller
Disk Controller : ASUS 6121 SATA2 Controller
USB Controller 1 : ASUS USB UHCI Controller #4
USB Controller 2 : ASUS USB UHCI Controller #5
USB Controller 3 : ASUS USB UHCI Controller #6
USB Controller 4 : ASUS USB EHCI Controller #2
USB Controller 5 : ASUS USB UHCI Controller #1
USB Controller 6 : ASUS USB UHCI Controller #2
USB Controller 7 : ASUS USB UHCI Controller #3
USB Controller 8 : ASUS USB EHCI Controller #1
FireWire/1394 Controller 1 : ASUS FW322/323 IEEE1394 OHCI FireWire Controller
System SMBus Controller 1 : Intel 801xx/63xx SMBus
Network Services
Network Adapter : Atheros AR8121/AR8113 PCI-E Ethernet Controller - Packet Scheduler Miniport (Ethernet, 100Mbps)
Power Management
Mains (AC) Line Status : On-Line
Operating System(s)
Windows System : Microsoft Windows XP (2002) Professional 5.01.2600 (Service Pack 3)
Platform Compliance : x86
  #59
Old 10-25-2008, 07:33 PM
Bill_Urick Bill_Urick is offline
Originally Posted by mano111 View Post
Thank you!
  #60
Old 10-25-2008, 10:21 PM
This is unusual in that it doesn't have a version number. I don't have EZPlayer to check this against, but you may want to be sure you're on the latest version.
These need to be updated - they're at 1.3.x, if I'm not mistaken.
This needs to be updated to 1.0.3 or higher.
Start there and see if that helps - make sure to trash preferences after updating or removing plug-ins...
Support FAQ
Pro Tools 11 Play-Pause Issue ProdGawd Windows 7 12-12-2013 05:22 PM
PLAY / PAUSE - Issue ... Once More !!! Zergei Pro Tools M-Powered (Win) 2 12-27-2009 11:50 AM
Some info on the Play Pause Issue Fastermouse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-31-2009 05:18 PM
Play/Pause Issue Resolved - Maybe? Try This. epu 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 167 06-20-2009 08:42 PM
cursor issue driving me nuts!! stevesound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-12-2006 03:21 AM
