third party audio interface
am considering Pro Tools 11 on windows, is the focusrite saffire pro 40 compatable?
Re: third party audio interface
I tested Pro Tools 11 on my Dell Optiplex 990 work PC (with only the internal soundcard, no interface at all) and it worked fine. Used the Asio4All drivers. http://www.asio4all.com/ You will need an ilok also. |
Yes it is :)
If you are on a PC I would recommend you first check out that you have a compatible Firewire Adapter via this Guide. If you are on a Mac you are fully compatible either through existing Firewire Adapter or the Apple Thunderbolt to Firewire Adapter. Best regards.
Katherine Kaplan // Focusrite Technical Support http://www.focusrite.com/answerbase/en/ |
DSP in a 3rd party audio interface | RuffinMedia | macOS | 5 | 03-08-2012 01:10 PM |
PT 10 with 3rd party audio interface and 5.1 setup | RuffinMedia | Post - Surround - Video | 5 | 02-15-2012 08:30 PM |
PT 10 3rd party audio interface | RuffinMedia | macOS | 9 | 02-15-2012 05:36 PM |
3rd Party audio interface - can it work? | tih | Pro Tools M-Powered (Win) | 2 | 10-16-2006 02:08 PM |
3rd Party Audio Interface | vico | Pro Tools TDM Systems (Mac) | 1 | 01-31-2000 06:29 PM |
