Old 07-03-2022, 07:34 AM
biasrocks biasrocks is offline
Default Record '3' on keypad no longer works in latest version
The record button '3' on the keypad has suddenly stopped working after the update to 2022.6.
Numeric Keypad is set to 'transport' in options, it appears that none of the keypad functions are working anymore
Any ideas where to look
HD Native, Windows 10 latest version
Old 07-03-2022, 09:31 AM
AlexLakis AlexLakis is offline
Default Re: Record '3' on keypad no longer works in latest version
Working fine here.
Silly thing, but are you sure NumLock is on?
Old 07-03-2022, 02:44 PM
That solved it. Thanks.
Pretty sure it didn't have to be on before.
Originally Posted by AlexLakis View Post
Working fine here.
Old 07-03-2022, 04:14 PM
Hmm, the same thing bit me
Old 07-03-2022, 04:20 PM
The Weed's Avatar
The Weed The Weed is offline
AFAIK, the numbers on the Num Pad won't work if the Num Lock isn't on.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 07-04-2022, 05:34 AM
Stephen Bond's Avatar
Agreed.
If Num Lock if off then the keys are sending out things like cursor commands rather than numbers.
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Old 07-05-2022, 06:21 PM
Drywsef Drywsef is offline
Yep. This is new behavior. Num lock did not need to be on before.
Win 11 22H2 - PTU 2023.9 - HDX - Blue 192 - Prism Titan
i9 10900K, Asus Tuf Gaming Z490 Plus, Corsair Vengeance LPX 32GB, NVIDIA 1070ti
OS/apps, sessions, and samples all on separate drives.
= key keypad no longer highlights transport #'s -Mac Catalina latest version ProTools MixerGuy Pro Tools 3 01-09-2022 08:48 AM
Latest OS X that works with The system 5MC The golfer System 5 6 01-05-2020 01:01 PM
Coreaudio on Mac Pro no longer working after latest PT 10.3.2. Update jdholman1 macOS 2 11-13-2012 10:32 AM
PT LE 7.4 no longer works on 3 different PCs AlyssaG 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 12-19-2008 11:27 AM
Latest ProTools version that works with AMIII Fokke van Saane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-05-2005 05:54 AM
