Old 02-28-2010, 12:32 AM
StudioRat81 StudioRat81 is offline
Default Axiom 61 recording duplicate notes in Pro Tools MP 8.0.3
Recently, my Axiom 61 has started duplicating every note I play. When I look in the MIDI Editor window, I can see the notes I played, but tucked underneath each one of those is a very short duplicate note (you have to slide the correct out of the way to see the duplicate). If I use the Event > Remove Duplicate Notes command, it gets rid of the extras, but that doesn't help me when I'm playing in real time as they seem to cause all kinds of weird things to happen with certain VIs. I have tested the Axiom on two different computers and gotten the same results. Is there a setting inside of Pro Tools that could be causing this, or is it more likely an issue with the controller? Any help would be much appreciated. Thanks.
Old 03-16-2010, 09:57 PM
mfb mfb is offline
Default Re: Axiom 61 recording duplicate notes in Pro Tools MP 8.0.3
I have the same problem using a Nord Stage EX with PT.. Did you ever figure out the solution?
Matt
Old 03-16-2010, 10:50 PM
Matt
Well, turning the Axiom 61 off and back on while still in Pro Tools seems to temporarily fix the problem, but it comes back eventually. I haven't found anything as far as a permanent solution, and my e-mails to M-Audio support have gone unanswered
Old 03-25-2010, 04:51 AM
DeButte DeButte is offline
Question Re: Axiom 61 recording duplicate notes in Pro Tools MP 8.0.3
I have the same problem, hope someone has a fix.
DeButte
MacPro 2.8Ghz 8 cores, 12Gb Ram, Pro Tools 10, Eleven Rack, Mc Mix
Old 04-08-2010, 03:53 PM
blackmacdaddy blackmacdaddy is offline
This may help?
Under the OPTIONS menu check that MIDI Thru is not checked.
Best :)
Walt
It's only R'n'R but I like it.
Last edited by blackmacdaddy; 04-09-2010 at 12:43 PM. Reason: it's Option menu NOT Event menu :)
Old 04-13-2010, 12:30 AM
gruddlebug gruddlebug is offline
Hello,
On the Axiom you may have multiple zones selected, which will send multiple notes to Pro Tools if the zones overlap.
Set to one zone only by pressing the Zone/Group button, followed by the zone number (1-4), then the Zone/Group button again.
Cheers
evs
Old 04-13-2010, 08:28 AM
spidey01 spidey01 is offline
Thanks for the info
Old 02-26-2015, 08:17 AM
x9blade x9blade is offline
http://duc.avid.com/showthread.php?t=364794
This cured the double note midi issue for me
3930K I7,X79 asus,GTX780,Samsung SSDx2,Western Digital Black 2TB HDDx4
32 Gb Corsair ram,30"Apple Cinema Screen,HD NATIVE
duplicate notes problem in 11 x9blade MIDI 2 06-04-2014 05:33 AM
Duplicate MIDI notes? Monaco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 10-08-2013 01:29 PM
MIDI Editing duplicate notes AMcG Pro Tools 9 1 10-26-2011 07:28 AM
Duplicate MIDI notes with AXIOM 61 problems proverb18 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-07-2007 02:43 PM
Duplicate MIDI notes with AXIOM 61 problems proverb18 MIDI 0 09-07-2007 09:56 AM
