Old 03-15-2010, 10:20 PM
JNS JNS is offline
Default SCSI anyone?
Hi. I'm running PT8.0.3cs1 on an 8-core MacPro. I currently have it set up with a 500G SATA drive for the audio. Unfortunately, right before I got my HD system I bought about 5 new high capacity (for SCSI anyway) SCSI drives to use with my MIX system and G4. This doesn't count the approx. 8 other SCSI drives that I already had. I'm thinking of getting an ATTO ExpressPCI UL5D SCSI PCIe card and using these drives. Is anyone running SCSI drives with their MacPro and PT8. They never missed a lick on my older system so I was hoping they would be good with the HD rig.
Thanks,
Jeff
HD3 Accel with 2-192s(expanded) and Rosetta 800, PT 8.0.3cs2/10.5.8 on 8-core 2.8 GHz. MacPro with UAD-2 Solo/Duo and Magma Expressbox4 chassis, Sync I/O, Midi I/O, Control 24;
PTLE 8.0cs3 on Dual-core 2.3GHz. G5(PCIe), 003R
Old 03-16-2010, 09:25 AM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
Default Re: SCSI anyone?
We've been running 4 systems on G5s with Ultra-SCSI since early 2004. NEVER had issues with them. Of course now we have to upgrade to MacPros and change all of the cards... very expensive to do, but if we've got room for an ATTO card in there, I'd stick with SCSI. You can't beat it's built-in housekeeping!!
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 03-16-2010, 10:22 AM
Delta Music Belgium's Avatar
Delta Music Belgium Delta Music Belgium is offline
I'm also still using UW-SCSI on my G4's and G5's with several ATTO ExpressPCI UL3D SCSI PCI cards and it is rock solid for many years now. If I should upgrade to a Mac Pro I would also try to go for an ATTO ExpressPCI UL5D SCSI PCIe card so I can continue using all my 10.000 RPM UW SCSI HD's.
I have no real life experience with a ATTO ExpressPCI UL5D SCSI PCIe card in a Mac Pro, but it is listed as compatible with PT, as you can read here
Marc Schellekens
Delta Music Belgium - Dolby Atmos Music Studio
https://www.deltamusic.be
Mac Pro 2019 - 3.2GHz 16-core - 96GB RAM - macOS 14.4.1 - PT HDX3 - Pro Tools Ultimate 2024.3.1 - Avid HD I/O 16x16 (x2) - Avid HD I/O 16x16 Digital - Digidesign 192 I/O - Digidesign 192D I/O (x3) - Avid SYNC HD - Apogee Big Ben - Apogee Rosetta 200 - Avid S3 - Slate RAVEN MTi2 (x2) - iConnectivity mioXL (x4) - Genelec ‘The Ones’ 9.1.6 Dolby Atmos Music monitoring (AES/EBU) with 8341A (x5) + 8331A (x10) + 7360A (x2) + 9301B - Almost all available AAX-DSP plug-ins
Old 03-16-2010, 10:53 AM
zodo zodo is offline
Apparently only the standard UL5D card is supported by PT...the UL5D-LP (low profile model) throws a stream of errors.
Old 03-16-2010, 12:03 PM
JNS JNS is offline
Thanks. I think I might just try it. My UL3D has been fine for about 8-9 years now. Hopefully, the UL5D will perform as well.
Jeff
SCSI 64 / SCSI drive options.. help! Richard Conrad Pro Tools TDM Systems (Mac) 5 04-03-2005 09:34 PM
Other SCSI PCI cards, than SCSI|128Kit which work? edgarbc1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-17-2004 04:54 PM
Performance : ide = scsi = ide+scsi ?????? mucky 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-25-2003 12:03 AM
hard drives: to SCSI or not to SCSI? Okion 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-28-2002 04:57 PM
Does Masterlist support SCSI CD-R on a Orange Firewire-SCSI adapter ?? dw Pro Tools TDM Systems (Mac) 0 12-26-2000 05:05 PM
